Subwoofers
#31
Re:Subwoofers
the back seat and box and everything custom...um...about $3000. but i could get in done without the fiberglass box and it would be around 1500 or less.
#33
I went with two JL 8" subs. I built the boxes myself to fit under the back seat and fire forward. I'm running a Zapco 360 amp to run my subs and JL componet set. The Eclipse head unit with 8v pre-outs helps out nicely too.
#34
Re: Re:Subwoofers
Originally posted by hellotbone
I run 2 JL 12 W3's DVC subs in the rear built my own box. I run 1 rockfordfosgate comp 1000 mono block amp. I have 3 compontent in front 6.5 4.5 and tweeter. I have an alpine CVA 1005 in front with XBOX hooked up aswell. In rear I have just plain old JL 2 ways. Sytem if highly competitive and powerful. I have a some stuff kicking around if you are interested PM me.
Wow this thread is Old School I don't have any of that stuff anymore.
#35
Re: Re: Re:Subwoofers
Give me a couple days and I'll pull it and measure it for you its in my truck right now at home or I would measure it right now. My box took me about 4 hours to make one night 5/8 HIGH density MDF is what I used I don't want any flex. All joints are screwed and sealed.,
I don't suppose you remember to measure it for us enquiring minds, did you???
I'm still waiting to fiqure out how to put 2 12's under my back seat.
Chris
Oh Yeah, Just Playing, but "an elephant never forgets"
#36
Yeah I gotta do that Im sorry Im a huge flake when it comes to remembering stuff I was actully on my way out to do it the other day at work and something broke so I got side tracked. Im on it!
#37
Like I said, just playing, but I would be extremely grateful!
Thanks,
Chris
I forget stuff ALOT too, I don't know what I'll do when I get old, I'm only 19
Thanks,
Chris
#38
if you in want real bass stick with the JL's 12w6 i have 6 with 2 phoenix gold zx 500's pushing them and dam is it loud ( it's a nissan low rider don't tell any one )
#39
DUM DUM DUM DUM box dimension!
OK I don't know how to post them really, I can draw it out in cad but I don't know how to convert to a JPG to upload it so I can try to just post the dimensions.
OK its a Wedge style box. So the Front if the widest part and the rear tapers to fit under the seat. This box Accommodates (2) JL12W3's but not V2's they are taller and this is the max that will fit under the rear seats with no mods.
The front is 10 3/4" high and the rear is 6" high. Now you have to also add a block at the front or extend the bottom edge of the box (this is how I did it) so the OA front is 12" high. Now the rear needs to be raised as well to allow the subs room to breathe as well. So the OA for the back of the box has to be 7 1/2". The width from outside to outside is 51".
I can't describe the under dimensions which is where the subs sit this is just the dimensions of the box. If anyone know's how to convert a dxf file to jpg then I can proceed to draw it out in cad and send it to them.
#40
Take a look in my album. I have some pics of my sub boxes, they were built for 8" JL, but you might get some ideas to build you own sub boxes. Good luck. Also, don't worry too much about getting the exact air space for your subs as you can add polyfil. Here is a link to figure your air space.
http://www.the12volt.com/caraudio/boxcalcs.asp
#41
ill try to get pictures up but im in the process of making a custom box that goes under my seat because the sub i have now is stupid loud. i have a 18" cerwin vega in a custom isoberic chamber that takes my whole extended cab. i need somthing that wont blurr my vision. im putting 2 12" alpine type r's ill have pictures up soon
#42
I plan on running 2 Image Dynamics IDMAX v.3 12s powered by an MTX 1501D pushing about 2000wrms. For the boxes I havent decided yet, since I dont use the room underneath my seats, I was going to put a sub underneath each the driver and passenger seats, then I am not taking up any space that I was using. And I dont lose any room behind the seats where I have it packed full of stuff anyways.
They will be sealed enclosures, and probably covered in vinyl, I might glass them, but I am not sure yet. I will get pictures up when its all done though, it would be a nice alternative for us reg. cab guys who need to salvage all the space we can.
-Jared
-Jared
#43
i have 2 infinity kappa 10's in a downfire box under my back seat. Great fit and people can still sit in the back and have room for there feet. I have a cheapo pioneer 50x4 head going to a sony xplode or whatever it is called 780 amp. sounds pretty good.
Chase
Chase
#44
A word of caution to you all. I use to be BIG into systems. At one time I was trying to get Rockford Fosgate to sponser me. In my little saturn I had all RF. CD player with 18 volt pre outs and changer. 5.25 and tweets in custum kick panels with a 50.2 power amp. 8" subs built into the front doors with a 50.2 power amp, and 4 12" DVC in the trunck powered by 2 250.1 power amps hooked in parellel. Now keep in mind this was the old days when a 50.2 amp put out about 250 watts and the 250.1 put out 500+ watts. This system would put out 149.9 db (not bad for about 8 grand). Back to my work of caution, I now have a constant ringing in my ears. There is an actuall diagnosis for this but I cant remember what its called (I'be been to the doctor). Be carefull and listen to your music wisely. Dont listen to it at full volume all the time or for that matter ever. I have a few friends that also have this and it SUCKS.
