Stupid torque convertors anyways...
Stupid torque convertors anyways... Some carnage
Well after purchasing my truck w/ the tranny out I was told it had a performance single disk TC.
Got it sent down to our local convertor shop had it split, the guy replaced the stator, the clutches, the hub.
They said the way the torque was built it is able to handle about 200-/+ hp/tq or somthing, I forget the #s off hand.
Well.. after the first test drive seemed to be going smoothe, after noticing we didn't have lockup so went back to the shop connected the missed wire.
took it for another spin, hit lockup started shuddering and we lost everything..
Well here is the aftermath
![](http://img.photobucket.com/albums/v239/cooleo42/DSC01583.jpg)
![](http://img.photobucket.com/albums/v239/cooleo42/DSC01582.jpg)
![](http://img.photobucket.com/albums/v239/cooleo42/DSC01581.jpg)
As you can tell from the TC picture it was pretty messed up.
The convertor shop/tranny shop tried blaming it on the flywheel and didn't wanna warrenty it, pay in/out fees, or replace the shaft.. so I took the flywheel down Monday, along with the TC. The supervisor looked at the flywheel handed it back said it was O.K, then they continued to cut the torque.
They could not find the pump stator at all inside the TC and I know its not @ my shop... well the stator was broken into 4 pieces, and everything else was mangled....
Just wanted to share this ;P
I think I'm going w/ a single DTT convertor.
Flywheel? Theres your problem right there. You need to have a flex plate hooked from the crank to the TC.
The shuddering broke your input shaft. It shattered and took your TC and front pump. Seems to me that you broke all those goodies yourself.
You had a classic break, thats what happens to most when they lose them.
Here is another type of break. This would be considered the good kind.
![](http://i67.photobucket.com/albums/h308/jon20012500/BrokeInputShaft.jpg)
If you use a lockup device you should have a billet input.
![Laughing](https://www.dieseltruckresource.com/forums/images/smilies/laughing.gif)
![No No](https://www.dieseltruckresource.com/forums/images/smilies/new1/nono.gif)
Yea I had a brain fart there.. flex plate..
anyways, nice pic too :P
And the problem occured in the TC, not in the shuddering.
As I stated the flexplate is fine.
The stator in this TC is made of the cast-alluminum, not of steel, like the DTT ones. But I do know the problem started in the TC because the first couple runs w/o lockup and o/d it ran perfect.. once it hit od and into lockup the TC shudderd and then it broke some things..
I'm agreeing with Justin. Looks to me that the input shaft failed.
With the converter unlocked the energy is absorb in the fluid. Once locked up all that torque is transfered directly to the input shaft.
fishin fever
02-09-2006 08:49 AM
