Stumble when on the go pedal
Is it possible that an injector line can be sucking air and not leak fuel?
My truck starts & idles fine, and normal driving is fine. When I get on the go pedal hard, it stumbles and misses.
24v, disconnect your DD true torque module so there are no electronic enhancements to the injection pump, then drive it. if the problem is not there or much improved, i will bet that its the early signs a VP44 heading south for the winter.
mine did it with a drag comp, and a buddy's truck does the same thing with his comp. the fueling boxes put that extra strain on the VP44 at wot and when they start to fail it will buck, surge, stumble, pop, etc when getting on the throttle.
burndiesel
11-18-2014 10:02 PM
600 Megawatts
03-26-2008 07:09 PM
