stumble at 1500 rpm or so
ok i put in a set of 370s, bhaf 4" exhaust and i have been having fun. i had this stumble before, but it shows worse now. if you punch it just sitting there it will stumble at around 1500 or so then shoot past no problem. it pulls well in 3,4 and 5th but you will feel it in second. i have not set my timing yet, that will be tommorow. i don't see any fuel leaks. any ideas besides timing??? thanks mike
Re:stumble at 1500 rpm or so
Hey lemme know what you figure out mine does the same thing and its only in second gear right around 15-1800, especially if its cold. Just send PM me when you figure it out if you wouldnt mind :.<br> Thanks<br> Wheels
Big blue My truck did this for about a year. The best thing I did to get rid of it was to go to the FMS by blue chip and the suncoast TC. This combo helped alot, but did not go away until I changed to the step #5 and the HX40. Ovetfueled
I think the reason that it is doing this is that it is throwing to much fuel in to it with no boost so it kind of tries to kill it self. That, and the high stall TC doesn't help much.
skeeter
01-18-2006 03:17 PM
