Which studs for fire ringed head
Old 02-04-2009 | 02:47 AM
Bjans's Avatar
Im getting ready to put my head back on and i have a set of the regular arp's sitting on the shelf i was planning to use, but i always second guess myself on stuff so i want your opinions. Should i go with 625's or just stick with the regular arp's? How many retorques/heat cycles?
Thanks
Old 02-04-2009 | 03:14 AM
Fishin2Deep4U's Avatar
How much boost? Lots of guys running the regular studs over 80PSI and big HP. If you are running nitrous or lots of water/ meth, they may be a good investment.
Dave
Old 02-04-2009 | 03:20 AM
Bjans's Avatar
75 to 80 I'm guessin! Not too sure, I'm doin a lot of different things to the truck right now but I don't want to have to do it again. I'm not opposed putting some nitrous on there if I get the bug, but rright now it is a little ways off!
Old 02-04-2009 | 09:54 AM
97' CTD's Avatar
If u are using the 62 in your sig. boost should not be above 45 pounds at most 50 if u plan to fog it hard with juice u need to run a Ex. gate to keep drive pressure in check they can be found here www.engineereddiesel.com. The ARP 2000's will be ample these are what I am going to run in my build.
Brandon
Old 02-04-2009 | 12:11 PM
Bjans's Avatar
Brandon
That will be the small charger in a set of compounds. Before i tore everything apart i was in the high 50's for boost
diezel freak
10-28-2009 07:56 PM
Bswope
04-12-2009 12:14 AM
mhuppertz
11-10-2006 12:12 PM
clawson
01-12-2006 09:52 AM
storx
44
09-30-2005 04:36 PM
