stronger clutch
stronger clutch
A friends 2000 ram 3500 clutch is slipping bad after putting an edge comp on. We believe it may have some injectors on it too from the previous owner. I have searched but not finding a ton of info but he can't afford a $800 south bend clutch but is there a stronger than stock clutch more in the $400 area or so that people have had good luck with? Is there any clutch style that we should stay away from? Thanks.
I think that LUK clutches are around that price range. There are a few guys who have had good luck with these. I went with the Con FE south bend clutch but they are a bit more.
you might check around you local towns and see if you cant come across a clutch builder. i picked a ceramic coated with kevlar 400+ HP for around 100 bucks at a local builder.
had one, lasted 15K miles, and went out... A stocker is stronger than a centerforce by far.. ID say a good southbend clutch is the way to go, if he is gonna run that truck hard, just turn downt he comp and baby the stocker for a while till he can save up 800 or so..
Rick
i juat got a 500+ horse clutch and i have a drag comp and a b1 turbo and 712s injectors and it is doing a fine job. the injectors are just in there for a bit my 312s took a crap and getting fixed. south bend clutch the way to go
was reading about the 13" flywheel upgrade. This truck is for hauling heavy trailers and the only thing he is going to do is bigger exhaust (supposedly) but just the box for power mods. Is it going to be worth the extra expense for the 13" versus the stock clutch size? Thanks guys
I got a good price on a SBC from http://www.trediesel.com/
Ask for the DTR discount
KVD
07-03-2007 06:38 PM
kelownadiesel
11-15-2006 11:56 PM
Nick Bazil
08-21-2006 12:16 PM
