Strange thing happened tonight coming home
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
Coming home tonight I go on to the skinny pedal pretty heavy. Watched the Fuel pressure drop from 13 psi down to about 7psi. Stayed in it a little longer and looked at the guage again and it had dropped down to 3 psi. Backed out of it and pressure only cam back up to 5 psi. Then I started nursing a little. after a few minutes the guage started bouncing back up to 13 psi and after a couple of miles it was holding steady at 13 psi.
Do you think it is possible to cause enough vacumn in the fuel line to drain the pressure guage line?
I figured my LP was on its way out... but its still going...
LP is on its way out. Some of the same symptoms I recently have dealt with...
https://www.dieseltruckresource.com/...251#post912251
Hodges4x4CTD
11-06-2008 08:25 AM
