Straight Piped 12v ???s
Hey, I just got some b-day money and Im considering putting on a straight pipe, so I have a few questions...
#1 How much will it increase the noise levels???
#2 How much power gain will I see???
#3 Does any one, other than Genos, make an elimination kit???
#4 How much would an Exhaust shop charge ....guesstiment???
Thanks,
Sam
Thanks,
Sam
Re:Straight Piped 12v ???s
Hey Greyboy, here is my experience with removing the muffler and cat. converter.
#1 The noise level will increase quite a bit if you remove the cat and the muffler
#2 Not much if any.
#3 I went to the local muffler shop and bought a piece of 3" pipe and had then flare each end. I replaced it from the down pipe all the way to the tailpipe with a straight piece of pipe and made some hangers. The pipe was $47.00
#4 Most won't do it unless you know somone.
Hope this helps,
Darrin
#2 Not much if any.
Hope this helps,
Darrin
[quote author=darrin link=board=7;threadid=22100;start=0#msg206793 date=1068173768]
#2 Not much if any.
Hope this helps,
Darrin
[/quote]
I disagree with reply #4. A lot of exhaust shops have no problem straight piping diesel's. Mine did it for $60, but I've heard of it being done for as low as $25 on the 'net. No way to see except for going to your local exhaust shop and pricing it.
#2 Not much if any.
Hope this helps,
Darrin
[/quote]
I made a phne call, drove in, the guy put my truck on the rack, made the pipe and welded it in for only $40.00, only catch was he wanted to back it out and hear it idle. It drew some attention when I left ;D
Thanks for the help guys, Im gonna call around today. I rather not do it myself if I can help it...I have a tendency to cause damage!!!
Dodgezilla
42
10-24-2002 05:12 PM
doomgaze
10-16-2002 11:11 PM
