Straight Pipe Drone!!!
This 2ft straight pipe dumping right at the t-case is getting old quick. Can't stand to drive more than 10 miles on the highway. Where can a guy order 4" flex for the exhaust?
Does the flex pipe leak much? I tried some aluminum appliance stack vent flex and it blew open first romp on the throttle.
How well does the flex hold up long term? I could go through the hassle of fitting this pipe up and welding it solid but a 2' piece of flex will fit perfectly from the 3rd gen down pipe to my existing mbrp 4" system. Are 4" guillotine clamps big enough for flex or do I need 4.5"?
You guys with stacks, how well is the flex holding up?
Any truck shop should have it.
I found this place awhile back, they've got everything. http://store.airflo.com/exhaust-tubing.html
I had 5" flex to go over the axle when i was running the exhaust out the back and it always did good and never leaked and make sure you use band clamps to seal the connection better. I like the clamps with the stepped part in it since you will be putting the flex over the pipe they just seem to seal better to me.
I have a full 4" MBRP with muffler that exits behind the rear wheel. I recently upgraded my turbo and the 3rd gen down pipe does not turn down far enough to clear the cab and make a smooth transition into the old system.
Truck was quiet like usual when I had aluminum flex on there for 10 minutes. I guess I'm going to have to call around to the big truck shops up in salt lake, otherwise Airflow online it is.
this is one of my delemas, we are gonna run 4" turbo back all pipe with 2, 4" stacks in the bed i am hoping with the ext cab it won't drive me nuts but i am figurin i will probly need to add a muffler later
how loud stacks are depends on how many bends you have in the exhaust. and how high above the cab they are. if they are almost level like my single 6" stack thats offeset is straight piped with only 1 bend in the exhaust besides the downpipe its pretty loud. and with all the windows open in my reg cab you cant talk to the passenger but with the windows up its not too bad but the straight pipe drone gets much worse when the the lowest point of where the exhaust exits isn't above the cab like mine
see how its barley above the cab at all.
this is how i first had it nice and deep much higher above the cab but the exhaust wasn't sealed all the way. so i pushed it all down and its sealed but much louder in the cab.
well I figure straight to the rear of the cab, a 90* up into a T splitter then a 90* at each end of that with the 4" chrome pipes curved out at the ends and around 1' above the cab(this is how we normaly do it) just did a 05 ford diesel and did an 04 ram diesel before that
I used my factory tailpipe for mine 90* angle, I had a short piece of 4in flex but couldn't get it to flex into a 90*. I had the factory exhaust off and layin in the shop floor and at the end on my factory tailpipe it went from 3.5in to 4in for the tip It turned out perfert for my stack setup. However my dads 2001 the tailpipe is different.
Ive noticed a difference in stack height and style, curved being quiter in the cab than the miters I have now.
I am surprised more people don't care much for their sense of hearing.
Oh well, I'm sure some Gov't program will help pay for your hearing aids after all the years of abuse.
