STOPS pulling hard after 3800 RPM????
I have Helix II cam 5K's and plenty of fuel and air too? I wonder if I am running the cam out of it's perameters, or if it is a few things????? Any clue. Just kind of lays down and is slow to pick up anymore speed or RPM's
Brandon
Brandon
Is that 40psi at idle or WOT above 3k RPM's? Might want closer to 30* of timing for that kind of RPM... Also do you have your drive pressure measured? It could be the cam but I kinda doubt it...
I would think it would be a lack of fueling. But that's just a guess.
What's the EGTs do at that rpm? If they drop, you are not fueling any harder. The suggestion to verify drive pressure is a good one as well.
I don't know what timing the high rpm motors like.
Dave
Dave
Eric
it sounds like your turbo is out of its efficency range. 40psi doesn't seem like alot of air at 5000rpm.
