Stock LP & FASS 2
Stock LP & FASS 2
Hello All,
Thought some of you might benefit from the following information. I received my FASS 2 System today. For those of you who don’t know, the FASS 2 is the FASS System minus the filtering system. It is $200 less, but the kit comes with everything you need for the complete installation of it and also carriers the same 4 year guarantee as the original FASS System. Mine is for my 2002 and the fuel line connects right to your stock fuel filter housing. This way you utilize the stock fuel filter, the fuel heater and the “water in fuel” sensor. The kit includes an in-line fuel filter as well that goes between the fuel tank and the pump, so you have a filter both before & after the pump. This looks like a very solid unit, especially when compared to the stock lift pump. The instructions are well laid out and it looks to be a relatively simple install. I will find out tomorrow when I put it in.
BTW – I am just a member here and have no ties what so ever to FASS. It is just the system I decided to go with to replace the stock lift pump. I will also be installing a fuel pressure gauge in the cab as well.
My Best, Greg
My Best, Greg
I finally got the time to install my FASS II today. Fairly simple, but the kit was missing hose clamps. A quick trip to the hardware store and & was off & running again. They need to add wire ties to the kit.
I remember reading somewhere about the fuel pressure guage becomes boring with a FASS because it rarely moves even at WOT. They were right.
Idle = 17.5 PSI
Cruise = 16
WOT = 15
4 year warranty, unlimited mileage, I'll buy the clamps & wire ties.
I'm gonna miss watching the stock LP pressure bounce all over the place. NOT!
Now I'm ready for some bombing baby!
Idle = 17.5 PSI
Cruise = 16
WOT = 15
If you need me, I'll be over at www.walbrorules. com
Originally Posted by P.J
WHAT? Oh, heck no, I would have boxed it up and returned it at that point! You were warned about FASS!
Originally Posted by lezmark7
Who do you guys recommend for the best price? Thanks.
http://dieselram.com/cgi-bin/ultimat...c;f=5;t=000684
Just to "Nit Pick" a little.
FASS stands for Fuel Air Separation System. There is no FASS II.
There is a HPFP...High Pressure Fuel Pump.... also mfg by DPP (the maker of the FASS).
Probable just me, but reading FASS II is right up there with "Cummings" and calling diesel fuel "Gas".
I feel better now! Have a nice day.
RJ
RJ
RJ
RJ
Actually, HPFP stands for High Performance Fuel Pump, but hey now I'm nit picking.
FASS II is quicker, (and better)
Originally Posted by 043500QC
Laugh all ya want, it works and it works well.
IMHO with the unregulated bypass you are starving the VP-44. The pressure readings drop to 10PSI WOT right? That reading is taken at the fuel filter right? The bypass located upstream of the filter is cutting the pressure in two right? That means you are running WOT at 5 PSI or less?
Hopefully, (I want to see the Walbro pump work) the volume is good enough? Has anyone done a flow test for fuel coming out of the VP? The bypass may even be allowing less fuel into the VP for critical cooling and lubrication.
Any bombing other than stock and you have a starved VP-44. This Walbro set up may work as a replacement for the stock LP, but it is not a good idea (YET) for any bombing setups? I'm asking, not stating a fact.
I'm not bad mouthing anybody, just looking at the info.
Originally Posted by 2002cumTRBODSL
Hello All,
My Best, Greg
My Best, Greg
Originally Posted by Geico266
I would like to have a civil discussion about the system you guys have come up with, and congratulations on the first systems.
Now, with all that said, I`ll try to answer your questions to the best of my ability.
Thank you for the congrats, and I also congradulate you on your FASS install, I truely hope it works well for you.
If the WOT PSI is 10 at the filter it only stands to reason if you have 2 return lines the pressure is cut in half after that right?
OH! Wait a minute! There is a bypass, but it still goes back to the original return line right? There is only one return line this causes the back pressure. Got it!
.......................... never mind.
I'm glad you guys have come up with a fix for the stock LP. I really am! If I was looking for a stock LP replacement I'd be a Walbro man. I went with the FASS II for the warranty and future bombing plans.
