Stereo questions.
What we did with Big Blue's box is right here.... click on link
http://images.cardomain.com/member_i...12_42_full.jpg
http://images.cardomain.com/member_i.../282112_43.jpg
And here is the seat riser brackets
http://images.cardomain.com/member_i.../282112_44.jpg
Quantrill sorry I havent gotten back to you but the links I just posted are exactly what BigBlue and I did for his box. The box wasnt hard to make if you can cut wood and use a nail gun or a screw gun and you can use caulk im sure you can do it. For the seat risers I 2 peices of angle iron and welded the side together to make a total of 4" of rise. Then just drilled holes then bolted. For the AW1206T's that size box would be perfect. The good thing for me is when I ride with BigBlue and he has alot of other poeple I dont have to call shotty cause I cant fit in the back. Being 6'3 doesnt work to well.
Sean
Sean
No prob. Sean, I did a search and was able to find those links from one of Tyler's earlier posts. Slowly starting to build it in my free time at work.
later guys
Jeff
later guys
Jeff
Originally posted by mooseman
im running a...jl stealth box with 2 10 inch jls powerd by a 500 watt fosgate amp with in dash bass control ****. i can take some pics of mine if youd like to see.
mooseman.
mooseman.
On one of my trucks im gonna take out the back seat and put four (4) AW1251T Audiobahn and a 2200HCT Amp. Im gonna have each one in its own chamber. Have all of them mounted inverted. With 2 10's I have in there now my back window moves so im guessing with the 4 12's im gonna have to get a new back window. Hopefully get it done by the end of summer
BlackSunShyne
36
12-15-2005 06:23 PM
vtailflyer
07-20-2005 07:15 PM
fahlguy
11-27-2004 09:16 AM
usedtostrokeit
04-24-2004 01:02 PM
