Steering Stabilizer
Steering Stabilizer
Hey all,
Im looking for some one in the Coquitlam B.C area who has one of those aftermarket steering stabilizers that just bolts on , has the bearing on it for the steering box .? Im hoping measure one and make it myself.
Thanks Redz.
2001 2500-FASS fuel system,boost and fuel gauges so far...
Thanks Redz.
I made on myself, and the materials are not all that expensive. I used to pices 2.5" x 2.5" angle 6" long 1 piece 1.5" square tubing can't remember the length offhand 1 piece .25" x 6"x 8" (I think) and a 1" flange bearing. I made a new nut for the steering box at work. I got the hole pattern dimensions at work. I will try and take some measurments and get you the dimensions tomorrow. I will try and get some pics up later. I just bolted the angle iron under the sway bar and then measured for the tubing and tacked everything together on the truck and took it of to weld it up. IIRC only took me a couple hours to do everything except make the new nut.
Joe
Joe
mercedeezel
13
10-13-2013 01:43 AM
EdmontonCanada
07-20-2010 04:57 PM
1985cucv
07-31-2009 03:33 AM
Rattlerattle
08-19-2008 05:14 PM
13ALPHA
07-09-2008 12:31 AM
