Stainless exhaust?
I'm sure that there are a lot of tehnical difrences, but 304 is a higher grade, I believe less carbon content. So it is harder to work with, but more resistant to corrosion.
What is the difference between grades of stainless (304, 321, 409…..?)
Without getting into the specifics of metallurgical properties, 409 is what is typically used on OEM applications. It has fair corrosion resistance, is magnetic due to the high metallic content, but is a less expensive material than 304. 409 is not an ideal material for a performance/restoration exhaust system because it will turn color (brownish/rust) from being exposed to the atmosphere without ever being run. For OEM’s who never care what the exhaust system looks like, it is a decent material that will last long enough to get past the warranty period. 304 stainless has much better corrosion resistance and a lower metallic content than 409. 304 will not turn color from sitting exposed to the atmosphere, and will only discolor slightly from getting extremely hot. The best thing about 304 is that you can maintain it with a scotch bright pad if you ever spill oil on it or have it discolour. 304 stainless, which is a premium mil spec grade of stainless that is more expensive than standard stainless in which is processed much more closely and is more consistent.
There are two primary categories of stainless steel tubing used in automotive exhaust systems: 300 series and 400 series. 400 series stainless is commonly used by oem for exhaust and manifold applications primarily because it handles heat cycling better than the 300 series. 300 series stainless becomes brittle after constant heating and cooling (which is exactly what an exhaust system does) especially in areas that incorporate welds. The issue of heat cycling is of great importance, especially in a heavy-duty application that will endure greater levels of heat than other automotive applications. Not only is 300 series stainless a poorer choice for exhaust systems, it is also more expensive and would unnecessarily increase the price of an exhaust system. 400 series stainless is not as pretty as 300 series and will have a brownish hue to it, due to the fact that it has a higher carbon content than 300 series. This means the 300 series stainless will polish up better for appearance. The carbon content in 400 series also makes it magnetic, unlike 300 series, which is a simple test to determine which series you’re dealing with. Fortunately, 400 series will handle temperatures of up to 2000 degrees without any deterioration, making it very suitable for use in exhaust systems.
Right! But when your stainless system is all rusty looking in a year it SUCKS
coobie
18
01-22-2004 06:53 PM
Lightman
24
12-04-2003 12:36 PM
