Stainless braided fuel pressure gauge hose
Old 04-11-2007 | 07:14 PM
infidel's Avatar
Originally Posted by P.J
I don't see what is wrong with using the nylon tube? I'm on my second truck, second application without a single issue......
11 years on each of my trucks with the same nylon tubing, not one problem.
I pass it though 1/4" tubing to act as a protective sheath though.
Before I went to mechanical had an electrical gauge whose sender leaked. Diesel wicked up under the wire insulation and dripped in the cab.
Old 04-11-2007 | 09:03 PM
Roadrunner's Avatar
Cool
The stainless line will make a nice hummmmmmm on the guage.I like heavy metal music and it still got to me.I run the tubing thru convoluted tubing to protect it.
Old 04-11-2007 | 09:13 PM
ellerman's Avatar
Stainless braided line can still leak when the rubber inside rots. I had stainless Earl's tracer line(very expensive) on all hoses in my sandcar and the fuel lines turned into a mister system this season. This made for a very dangerous situation when raw fuel was spraying all over the hot exhaust. I would save the money on the braided line and get some high quality Parker push lock rubber hose. Eric
Old 04-11-2007 | 10:12 PM
Deerefxr870's Avatar
Originally Posted by hamilton71801
Did you have a needle valve on with the SS? Right now I'm running nylon tubing with the needle valvle (barely open) and can't hear it at all. If it's going to be noisey with the needle valve, I might just re-think this.
I still have the SS, I just put the rubber hose in between the SS and my connection point to the system to isolate the vibration and noise. The rubber hose is actually low pressure hydraulic hose with nylon braiding. My needle valve is between the ruber hose and the SS.
Old 04-12-2007 | 04:01 PM
qwest's Avatar
OK again ,, 1/8 copper tubing , no leaks,
BC847
01-01-2007 12:07 PM
1882
09-02-2006 10:41 PM
rattle_rattle
13
05-15-2004 05:30 PM
Crimedog
15
02-09-2004 10:04 PM
Quick Reply: Stainless braided fuel pressure gauge hose
