stage 5 jammers
stage 5 jammers
I found stage 5 jammers and it sounds a little extreme for my truck....I dont know if these are just nozzles or they are injectors but it says..
DD Stage 5 Jammer 175HP High Recommended with NOS and twins, competition only
http://www.piersdiesel.com/DodgeInjectors.htm
is the link.....I was think about rv275's,mach 1's, or stage 5 jammer nozzles....I dont know where I can find the mach 1's or the jammer nozzles though....How would those nozzles work on my truck...I am all stock with the exception of a straight pipe...I have an 02 24V 6sp
I have the DD supermentals in mine. I love the things. They are a little less than the jammer 5's. with mine I have total control of smoke. they drive good around town and gave me about 1 mpg better. still on stock turbo and clutch and egt's are ok. hope this helps.
You can Super Mentals here: http://www.performancedieselwarehouse.com/820620.html
Just my opinion, but if you are going for some major sticks like that I would go for EDM injectors.I am sure the DD supermentals are fine injectors,but they are extrude honed.Which is kind of old technology.EDM's are definatley the way to go.They are a little cleaner and make a better spray pattern which atomizes the fuel better.I would want the Jammer 5's over the DD supermentals if it was me.Just my opinion though.Good luck
I have to second caleb. F1 sticks are the way to go. i like my dd's but i want F1 mach 5 or 6's plus the F1's should give you better milage. oh, i can smoke lots when i want too.
Thanks for the input.....I dont plan on running too big of injectors I think I am just going to run injectors and remain stock other than them for awhile so I want something big enough that will give me some power and let me smoke a good bit but not enough to harm things....Are the F1's up my ally?? And if I do decide to go with DD's will they be too much also....Like i said im just looking for some injectors that will make good power and smoke good but not harm anything because I am all stock with the exception of a straight pipe..
John
John
I dont know about you John but I am sick of buying things twice. I am ordering the jammer 5 nozzles today. I was going to get something a little smaller but I know Myself. And sure enough Ill be dissapointed if I dont get the bigones first. i did a search and there are quite a few on here that are running the stage 5 sticks on stock turbos.
So I am going for it.
After I get them installed Ill put a post of how well (or not so well) they work.
Have fun ...Jay...
Have fun ...Jay...
i would suggest buying an EGT gauge, fuel pressure gauge, and a boost gauge BEFORE any sort of power increase. the HO's have been known to run hot in stock form. without an EGT gauge the stage 5 nozzles would be fun until you reach meltdown...
before you buy use the search function with some key words such as "injectors" "mach" "jammer" "rv275" and listen to what others have said about their experiences
jhood12,
Tell us about how you use your truck, do you tow if so how heavy? Do you drive in the high elevations? How much HP do you want? Are you willing to upgrade your turbo or do you want to stick with your OEM model?
The F-1 injectors are the best injectors around! As with any mod you want to make the right choice...... Knowing how you use your truck and what you want out of it helps to recommend the proper size injector for you.
Doug
Doug
doug, I do tow with my truck but nothing too heavy....I mainly just tow my samurai on my car trailer....maybe sometimes a full size truck....I live in Indiana so no high elevations. I really would like to keep my truck as stock as possible...The only things I have been thinking about doing were gauges and some injectors and maybe eventually a box...
