Stacks and Sp66 are on!!!
Old 05-08-2006 | 10:59 PM
CTD2001's Avatar
This past weekend my buddy and i installed my 5" straight pipe miter cut stacks and my sled puller 66. All i can say is WOW, my truck absolutley hauls butt. I feel bad for my tires because they are seeing some abuse. It sucks because they are brand new and they were expensive, but the i can not resist the urge to hit the go pedal. The turbo is unreal, it seems to make much more power (SOP) feel then the super 40 did. I would say the the lag between the two is very small, the 66 is just a wee bit more laggy, but the more and more i drive it, the lag seems to be less and less. I would deffinetly not want to run this turbo with out a MAD ECM, it helps tremendously with spooling it up. I love my stacks, it was probably one of my favorite purchases for the truck. I have pictures of everything, but i do not know how to make the size, KB smaller so that they will be allowed to upload into my gallery. Does anyone know how i can change the size, in KB of them? Thanks
Old 05-08-2006 | 11:05 PM
Bobcat698's Avatar
I noticed that after a night of running HARD at the drag strip, the turbo started spooling up a LOT better.. Seemed to break in a bit.. This was at around 2,000 miles on the turbo.
You are going to love it!
Old 05-08-2006 | 11:07 PM
CTD2001's Avatar
yeah, i got about 200 miles on it right now, and everytime i drive the truck, it seems to spool better and better, i remember when i had my super 40 on there the same exact thing happend, was a pig at first but after it broke in, the lag seem to become less and less. What kind of Boost numbers are you seeing with your turbo? Thanks
Old 05-08-2006 | 11:11 PM
Bobcat698's Avatar
I'm at 44PSI right now.. Cleans up the DDP4 sticks pretty well.. I need to figure how to get MORE fuel! (besides 215 pump)
Old 05-08-2006 | 11:15 PM
CTD2001's Avatar
yeah, the max that i have seen on mine is 47 lbs, i have an adjustable boost elbow on it and i have not made any adjustments to it yet. Right now the allen screw is shut, turned all the way to the right, i am not sure if i will loose or gain boost by turning it to the left and backing off the set allen screw. Any insight on how these work? Thanks
Old 05-08-2006 | 11:21 PM
12valve's Avatar
how about EGTS?
and what kinda BIG DVs do you have? yeah, im interested too, if you need more fuel ot of the pump or the injectors.
Old 05-09-2006 | 12:47 AM
Ph4tty's Avatar
As far as resizing the pics open them with microsoft paint (comes with windows) go to image tab and select stretch/skew put in lets say 50% for horizintal and vertical then save and its now 1/2 size =P
Have fun with the SP66
Old 05-09-2006 | 03:31 PM
CTD2001's Avatar
Thanks for telling me how to change the size of the pictures, i just did that and they are waiting for approval in my gallery. I got to take some better pics of the sledpuller, i think i will go do that now
Old 05-12-2006 | 10:55 PM
CTD2001's Avatar
I just got my Tonneau cover back tonight, i had two 5 1/2 in holes cut in it and stiched up by a boat cover maker. I did a quick fit to make sure that i measured everything right, and by god, i made the right measurements. I will put it all together tomorrow if it stops pouring outside and i will take some pictures of it to see what you guys think of it. I am pretty excited about it and i think that it will look good when it is all put together.
Old 05-13-2006 | 01:39 PM
Moose10's Avatar
CTD2001, The stacks look great ! Where did you get them, and is that the SP66 in your gallery, or the old 40?
Old 05-13-2006 | 02:09 PM
Bobcat698's Avatar
Originally Posted by 12valve
how about EGTS?
I need more fuel to the injectors at this point.
My fuel pressure drops to 16-20 at WOT in overdrive.
Thats AFTER doing some AFC mods. I want to get my pump tuned.
I have laser cut dvs from Scheids.
EGTs are OK, they will peg obviously but you hit about 80MPH first
Old 05-13-2006 | 03:49 PM
Ph4tty's Avatar
Lookin good.
Old 05-13-2006 | 09:07 PM
CTD2001's Avatar
The turbo in my gallery is the Sp 66, I got some new pictures that i will upload now that have my tonneau cover on. I am happy with the way it came out, it looks really sweet. I got the stacks from a local distibuter for Grand Rock Pipes. I think i am going to be working out a deal with NOSPIN4ME for my super 40. He has a set of 200hp EDMS and we might work out a deal. I am excited to see what it will do on the Dyno next saturday the 20th.
Old 05-14-2006 | 10:35 AM
Ph4tty's Avatar
Tight
Old 05-14-2006 | 11:15 AM
CTD2001's Avatar
Hey, how did you get the pictures in the Forum like that, i could not figure out how to do it, i tried but with no luck, thanks
