Stacks
Stacks
I dont have the tools or the place to build the set of stacks that I want, wondered if anybody had a used set or could build a set for a resonable price. Thanks
You could get the pipes you need at a big truck shop.If you need special bends they can get then or make them right there.That's what i had to do on my tractor.I could bulid you a set but i hope you can find someone closer to you and not in PA.
i saw kyle michaels old stacks on his web site www.crankitupdiesel.com it came with the y-pipe and 6in stacks it was on his chevy but they would fit a dodge just the same and he only wants $250
i paid about $500 for mine and that was just parts and i already had the down pipe your looking at about $500-600 for a stack setup. $250 is a heck of a deal and you could reduce them to 5in but why would you do that
I have the crossover box in my bed one inlet lined up with downpipe a divide in the intake side of box and then two outlet's on top of box. Box is constructed out of 6x6 tubesteel with the ends welded up and angle iron attached to bottom of box for mounts. Cool thing about running crossover box is you don't need to move fuel tank and there is no bracing of the stacks required. I did not make the setup but I could easily replicate the only problem would be the shipping cost because setup is heavy.
nfsommer
21
04-04-2007 03:45 PM
rockittboy
02-03-2006 12:38 AM
