Stacking a TST with Edge EZ question
Old 10-02-2007 | 08:10 AM
mopar440cu's Avatar
I have an 01 Dodge and I want to stack the TST with the Ez Edge. Which would go first into the map sensor on the engine, then to the map harness?
Thanxs for any info!!!
Steve
Old 10-02-2007 | 11:18 PM
bama's Avatar
i always ran the tst first,then ez ..........bama
Old 10-03-2007 | 02:28 AM
MikeR's Avatar
Me too. Since the TST fuels by the boost signal, I always plugged the TST in first, then the EZ.
Old 10-05-2007 | 02:41 PM
mopar440cu's Avatar
Question
Thanxs guys, but not to sound stupid , do I plug the TST into the map sensor on the engine, then the EZ, then to the original map sensor harness? I appreciate all the help!!!
Old 10-05-2007 | 04:18 PM
RowJ's Avatar
It looks confusing but can only go together one way... once you start with the TST into the MAP!
-TST into Map sensor socket on block.
-EZ into TST wiring harness.
-Than the last 2 plugs left unattached (the Dodge Map plug-male) and the EZ female go together!
Don't forget to also connect the EZ to the DATA port , farther forward on the block.
RJ
Old 10-05-2007 | 06:25 PM
Why_Try's Avatar
The above is 100% correct.
Have fun with the stack. your EGTs are going to hate you, and the people that have to follow.
Old 10-06-2007 | 08:48 AM
mopar440cu's Avatar
Thanxs she worked well for me!! The bicycles riding in the road creating a traffic jam hate it when I get to pass now, cause I just smoke them terrible when I pass them!!!!
Now if I can just change the HX35W Holset that was intalled on my truck. It was a big mistake, lags alittle on the take off even with the elbow on it!!!
hotdram
03-10-2005 06:22 PM
cudamanjr
02-10-2004 06:57 PM
Zino
12-16-2003 06:19 PM
mcevins
08-31-2003 12:09 AM
