stacking juice??
Old 12-07-2007 | 06:07 AM
JSCumms2000's Avatar
stacking juice??
ok, well after reading over what i could find in the search field for what to stack w/ edge juice w/ attitude, i've come the the conclusion that i should ask again.. seems to be alot of mixed feelings on whats good to stack w/ it.. i know not to use a timing box, and edge ez wont work as well.. what are some good choices or what are my options as far as what module i can use... all opinions will help, thank you..
-Jared
Old 12-07-2007 | 07:14 AM
C2O's Avatar
C2O
what about the smarty
Old 12-07-2007 | 07:16 AM
cyric's Avatar
The Smarty would be a good stack with your Juice. Just run it on even number levels without timing. Your other options is to unhook the pump tap and run a fueling only box like a TST or Redline but I don't know if it is worth that. Just my $.02
Joe
Old 12-07-2007 | 10:39 AM
JSPulliam21's Avatar
A Smarty is just about the only programmer I can think of that will do fuel only, and fuel and timing. Even numbers on the Smarty will get you fueling only.
Old 12-07-2007 | 01:24 PM
C2O's Avatar
C2O
yep the juice and smarty were the stack that everybody has ran once.
Old 12-07-2007 | 02:17 PM
haloman's Avatar
I would second unhooking the pump tap from the juice and running a TST module.
Old 12-07-2007 | 02:23 PM
dzlfarmboy's Avatar
What are your " BullyBooster 8's suppose to be? If your looking for more power Stacking a Smarty with a Comp will gain you very little. I would opt for bigger injectors unless those you have are a 220+ stick. Then i would imagne you would need more air.
Old 12-07-2007 | 02:25 PM
haloman's Avatar
Bullydog 8's are supposed to be a 240 hp injector IIRC.
Old 12-07-2007 | 02:41 PM
dzlfarmboy's Avatar
Yeah some smokey 240hp injectors, if thats what he has, I would be looking for more air, instead of stacking more fuel.
Old 12-07-2007 | 05:50 PM
C2O's Avatar
C2O
are those rated 240hp, or are they called 240's
Old 12-08-2007 | 06:14 AM
they are 240 horsepower injectors... whats the best way to get more air?? other than nitrous... im looking into the twins, a lil home brewed version of my own... whats another good way of getting more air??
drew03
08-22-2005 07:03 PM
RamWheelsBy4
13
07-14-2005 08:36 PM
pquestad
03-28-2005 11:12 AM
1TONY1
01-25-2005 12:32 AM
