stacking fuel and timing boxes
ok so the fueling box(male end) plugs into the map sensor (female end), then the timing box (male end) plugs into the fueling box (female end) and then the timing box (female end) plugs into the map sensor (factory male end). is this correct?? and also the fueling box directions says to tap the vp wire. it says " at the back of the pump towards the firewall you will see two sets of wires, attach the blue wire tap that is closest to the engine wall. does anyone know what color wire this is? this is the new quad xzillaraider module, i am not sure if anyone else has any experience with this. thanks
DTR's Cow Boss
would stacking the van aaken and the new zillia xzt for the second gens be a good choice for lossa more juice? that might be worth looking to next year after my exhaust brake.
Registered
if you want a good stack, stack the smarty and tst pm3 comp. best stack out there IMO.
ive never ran a aaken or zilla, so i wont comment on them. the most power will be out of the smarty/tst
the xzillaraider i bought is rated at 120hp/325 ft lbs, it's the dxz98s model. and will fuel past 3200 rpms. quad has some new things coming out for the vp trucks that will be a hard competition for tst. i will let you know how i like the quad. i believe the xzt is a timing box like the ez, and van aiken.
Registered
the tst pm3 comp drains as much as you possibly can out of the vp44. (180 hp!?!?!) and fuels to 3400 (aint that right rjohnson?)
the quad wont be able to beat it, match it maybe.
quad is going to have a box that will compete with the redline, imho. this one here is enough for me. but the software upgrades are free when quad comes out with the new version with the aggresive fueling option. anyway, i finally got everything installed. all i can say is wow. i am not used to this power. i need a tranny soon. then it's time for sticks and turbo. i can only imagine!!
Registered
i've talked to dealers, and they say that the redline box isnt a very hot seller. Its just too expensive. And most people already have guages and dont need the extra set that comes with the box
now if zilla make a box that is competative with the redline with out the guages for about 800 bucks that may sell.
I have a question, do i have my box stacked in properly. Right now i have only the TST box connected to the map sensor and the only part of the edge box that is connected is the plug to the data link port. Do i need to stack the edge box map sensors inline with the TST maps senosrs? I thought i had it right the way it was, but maybe i have it all wrong, Thanks
trik396
02-20-2007 05:45 PM
t-boe
01-04-2007 08:35 AM
RonP
02-24-2006 02:12 PM
DieselGoose
06-20-2005 09:08 PM
