Stacking Boxes
Stacking Boxes
How do you connect two boxes that both require seeing the MAP sensor? My van Aaken has been connected to the MAP sensor for three years and the PowerMax instructions say it needs to be connected to the MAP sensor.
How do you do that?
How do you do that?
![Confused](https://www.dieseltruckresource.com/forums/images/smilies/confused.gif)
Thanks Guys, that is how I have it now, but I'm getting a higher idle (100-150 rpm) and a stumble at the same time. TST said that happens when the MAP sensor is clogged. Mine had a little bit of fouling on it, but it cleaned off easily and the problem remains. I also did the IAT while I was in there stretching across the top of the engine. That made no difference either.
t-boe
01-04-2007 08:35 AM
rubbert
13
04-22-2004 02:19 PM
John_P
24
07-13-2003 08:59 AM
