Stack with the edge comp?
Alright y'all...more stupid questions en route...I have finally managed to get the wire tapped for my edge comp. I have been browsing the forums trying to learn what I can. My question is regarding other programmers on the market. I have been reading good things about the smarty in particular, as well as others. Can any of these be stacked with the edge comp, if so, which can and which is the best? Thanks guys.
most people will say the smarty is the best thing to stack to it because the comp has timing and fueling and the smarty has a fueling only program built in it.
you are not supposed to stack two timing boxes on each other like the sc programmer and your comp. but ive always had good luck with stacking two timing boxes and never hurt anything, ecspecialy if you are low on funds like me and can pick up a sc programer for a couple hundred and compared to a smarty of around 650.00
lvmknsmoke..
08-13-2009 10:59 PM
dodgediesel
07-27-2007 08:59 AM
mx684
13
07-24-2007 07:52 PM
JD farmboy
05-21-2006 01:04 PM
rockjeep73
03-25-2005 03:34 AM
