SPS62 VS Aurora5000
I dont personaly care for ATS, so that alone would be enough for me to cancle the oreder. The 5000, if I remember right is the same as k31 which is smaller than a s400/b2. I'd personaly go with a s400/b2 set up. Probably cost you less to boot.
The K31 and S400 are apples to oranges. Both are very large and very close in size. I asked a Borg Warner employee what the differences were and he basically said the same thing. He said the S400 series was an american design he favored. He also said the K31 was from a German design and series.
An OEM performance borg warner K31 wastegated with large turbine housing and billet wheel that would be suitable for twins can be had brand new for $924.
The stock S400 can be had for around $650.
www.citydiesel.net has them...
I think you mean super phat shaft 62, but yes it will support 500."
I went with a SPS62 (currently still sitting on the floor) for what is an estimate 500-550RWHP I'll have. I did a lot of pokeing around and I think that was the right choice for me since its a daily driver in all kinds of driving conditions. Also its not so big I can still use it as a small turbo in twins if I want to upgrade without throwing out a turbo. If you do go with an SPS62 and may want twins later when you order it ask them to make the wastegate bigger so it can dump more if you do put twins on it.
Cant you pair a silver bullet with a sps62 for twins?
There is a new Silver Bullet 62 which has different exhaust housing "work" and some special stuff done to the wheel...supposed to flow better for higher power!!
Chris
Chris
II and HTT need to get on the ball with a marketing campain cuz these variants are really going to confuse folks.
So now we've got the s300's with the 58 compressor and 62, then 64 and 66 with a slightly larger turbine, then the sps/ ht series with the 71 turbine and now the silver bullet series with a 74 turbine. No wonder there are so many which turbo threads =\
Then back to the original poster's question, the a5k is a 71 compressor and 76 turbine,..... yeah I did a search
fjbiker86
22
11-27-2006 03:36 PM
Syndicate
05-19-2006 01:47 PM
metal_miner
03-18-2006 04:36 PM
