Sport light wiring
Sport light wiring
Just letting ya all know I drew up a schematic for putting Sportlights in. The wire colors are from my 2001 FSM. Your colors may vary. No wire cutting needed if you can find the blank sockets that are basically a bulbless bulb. I modded the 3 beam configuration from Daniel Stern lighting and also added a relay to keep all 4 low beams on. Also used a relay for each pair of filamnets. Let me know if anyone has any questions, or if someone sees something wrong.
Sport light wiring
Sport light wiring
~Nick
I'm so lazy. I'm only running the low beam filament in the 9004's. Basically just the "alt lo beam" part of the circuit. The light pattern is a little off to be used for everyday low beams IMO. They make excellent hi-beams! I have built a bracket to hold all the relays required, as long as the 2 junction points for the +12 and grnd. Like I said since I'm using just the hi-beam part of the sport lights, I had to adjust them differently as well, I think. I wont know how close the alignment is until I get the actual intended lo-beams fired up. Lemme know if u got any questions.....
airplaneman00
13
06-22-2007 10:20 PM
B.Law
07-18-2006 03:46 PM
mamm7215
07-15-2004 09:08 AM
brianflynhigh
14
03-19-2004 02:48 PM
