Spool up....
Yeah. I havent checked it yet, but i dont feel like i have a leak either. It spooled pretty wuick with the stock converter, and yes; I am running full boost still. Oh well. Its so fun once it spools that I can live with it i guess.
Eric
![Cool](https://www.dieseltruckresource.com/forums/images/smilies/cool.gif)
Eric
I guess the big cloud before boost doesent bother me so bad if I am kicking on it. What gets me is that it will haze if you just even barely step into it just running down the road, or taking off. I might end up trying a different plate sometime. Im pretty sure I can get the smoke down some doing that.
Eric
Eric
We have simalar DV's and the same injectors. Just for kicks move your AFC housing back or screw out the smoke screw just a bit and try it out. Mine blows smoke (bogs out) and inital spool is much slower if it is to far forwards.
EDIT: SORRY I SEE YOU ALLREADY TRIED THAT.
I havent had any luck yet. I have just been living with it. I have played with the starwheel a little without much luck in getting it any better. It just likes to smoke I guess
I still have a few things i want to try with it, but i havent messed with it much. I think my converter is just so tight that it likes to smoke. Its definately worth the trade off over a stock converter though.
Eric
![Dummy!](https://www.dieseltruckresource.com/forums/images/smilies/new1/smashfreakB.gif)
Eric
try pulling your fuel plate back a little? my truck smoked real bad and untill I pulled the plate back some. Cleaned up quite a bit and I didnt notice any loss in power. Also the slow spooling isnt that due to a really big exhaust housing? I have a 62/14 and its really slow to spool. I was told the 12 is alot faster. I'm not expert on turbos but wouldnt a 16 even on a hx35 still be the problem? With the loser converter your engine could spin up to a higher RPM befor lockup without all that load so thats probbaly why it felt faster.
Zino
07-12-2004 10:27 PM
Sarge1124
61
08-12-2003 07:30 AM
