Splitting grid heaters with Twin Ram ?'s
I've been trying to mock up a Twin Ram style intake for some time now, and am getting closer to trying to make something out of aluminum and try it on the truck. With the Banks manifold, do you simply take the heaters and seperate them, then run a jumper wire? Or how are they mounted? And is there a spacer in place to keep the manifold on level as if there were two heaters stacked? Thanks.
Twin Ram heaters are split into 2 heaters and one wire from the relays goes to each one,just as they are now when together.Here is one of the pages from the kit for you to look at........Andy
dra7
17
06-09-2005 01:26 AM
