Specs on the S400
Specs on the S400
Anyone have any specs
of the S400 commonly found in Rips Twins? Im most curious about the size the exhaust housing is as well as size of impeller and compressor wheels..
Thanks!
Rick
Thanks!
Rick
hey rick, well the compressor housing is 74mm and the exhaust is 26cm, as for more specs check out this place http://http://www.citydiesel.net/b2-...urbo-p-84.html hope this helps
jason
jason
Like Jason said...intake inducer is 74/75mm (some say one, some say the other, I never measured), exhaust housing is 1.32A/R, and the exhaust inducer is 95mm!
Chris
Chris
The 171702 S475 from Borg Warner has a 75mm compressor wheel at the inducer.
The 171701 which is also in the S4 line has the 71mm compressor wheel.
Both have a 1.32 A/R turbine housing and come on Detroit Diesel engines stock.
There is a brand new S475 on ebay for $525
Sixpack73
15
07-17-2009 07:31 PM
06RAMCTD
0
12-19-2006 04:15 PM
