specific smarty questions
Old 03-08-2006 | 10:22 AM
  #31
BigBlue's Avatar
I agree. I've been running around with my map unplugged for a while now and my spoolup is unaffected.
Old 03-08-2006 | 10:33 AM
  #32
getblown5.9's Avatar
if i unplug the map sensor and diagnostic plug, do i still need to unplug the wire tap?
also, if the MAP was unplugged, how could the faulty MAP affect spool up?
i will check and clear the codes tonight with the smarty
Old 03-08-2006 | 10:39 AM
  #33
BigBlue's Avatar
You don't need to untap the wire to unplug the comp. Just remove all of the plugs, gorund, and power.
I agree that if the map is unplugged then it shouldn't have any effect on the spoolup. Even if it's faulty.
Old 03-08-2006 | 12:22 PM
  #34
RowJ's Avatar
Originally Posted by 97whiteram
RJ... So were does your "LIL"55/14 light off?
James
Damed if I know. Seriously, it's a good question but with an Automatic..... it is what it is, and I'm watching other things when I go WOT.
By "light off" I assume you mean at what rpm does it start rapid jump to 45 psi? I will test it today... watching rpm's... and report back!
RJ
Old 03-08-2006 | 12:48 PM
  #35
id liek to know as well...mine i can roll into the throttle at 1700rpms and it starts smoking like a chimney, i have 10psi at 2200rpms and by 2500 its holding 45psi and everything just gets crazy, the noise, the acceleration, the excitement factor...but before then this truck is as boring as a stock gasser truck
Old 03-08-2006 | 01:59 PM
  #36
RowJ's Avatar
RJ So were does your "LIL"55/14 light off?
You guys had me curious, so I found an excuse to run into town.
My turbo starts a rapid climb to 45 psi at 1950-2000 rpm. (just under 2000).
Both needles are moving pretty fast, so it's hard to be positive... but I would say I hit 45 psi (wastegate setting) right at 2300 rpm.
By comparison, it sounds to me like your Lil 55/16 is doing about what it should!
RJ
Old 03-08-2006 | 02:04 PM
  #37
not according to JR...he says that both the guys who had this on their truck were lighting it at 1700-1900, one was a 12v and one was a 24v
Old 03-08-2006 | 02:31 PM
  #38
RowJ's Avatar
I would ask them to define lighting off!
My 55/14 starts building boost well under 2000 rpm, Climbs rather slowly to 12 psi boost and then rapid jump to 45 psi at 1950 rpm.
Did not try it from a dead stop and WOT... may be different??
RJ
Old 03-08-2006 | 02:34 PM
  #39
he defines lighting off or spooling as the rapid jump from about 10-45psi...that was at 1700-1900 on the other trucks. on my truck i have 10 psi until 2200...then it starts to build and by 2500 i finally have 45psi...oh yea, then it defuels and its pointless
Old 03-08-2006 | 06:43 PM
  #40
97whiteram's Avatar
Originally Posted by ky4wheeler
It is a 64/16. On my automatic i could get boost around 2000 and i could brake spool it to 30 pounds before busting the brakes loose.
[quote author=bpostel board=cp3 thread=1141305864 post=1141345025]Something doesn't sound right. I ran the lil 55 with a 16cm housing and it spooled around 1700rpm. Sounds like a stock 55 to me.[/quote]
[quote author=treed board=cp3 thread=1141305864 post=1141346184]My lil 55 with the 14 housing lets loose about 1650-1700rpm, pretty good I think.[/quote]
[quote author=clawson board=cp3 thread=1141305864 post=1141357487]My little 55 spooled around 1800 and then just took off.
That is the only bad thing about not buying a "new" one or buying it off anyone you know.
My 55 also had the 14cm housing.
Chris [/quote]
I found these on various other boards. These are post by actual owners and not the vendor. Im just trying to help here.
James
Backwoods Bumpers
10-02-2007 09:17 PM
Tim9712v
18
02-13-2007 11:35 PM
Eskimo
16
11-28-2005 12:52 PM
rockjeep73
03-25-2005 04:34 AM
keysersoze'
01-11-2005 01:47 PM
Quick Reply: specific smarty questions
