specific smarty questions
Old 03-07-2006, 09:14 AM
RowJ's Avatar
FYI
At 45 psi and 100+ mph, I'm at 1450* EGT's with a 14 cm2 turbine housing.
How fast it will spool depends on how much fuel and how it is delivered. Adding Smarty increased spoolup time considerably for me.... sooner and faster!
RJ
Old 03-07-2006, 09:22 AM
duallydave's Avatar
Talking
Originally Posted by getblown5.9
LOL thanks HOHN...i know a comp box going up for sale...put the money towards a smarty, then save funds for a TST fueling box.
i wouldnt get rid of the comp just yet.if you try it on #8 with your comp you will be all smilesssss
Old 03-07-2006, 09:27 AM
getblown5.9's Avatar
JR says $600 plus shipping for a WG 14cm housing...or i can get "smart" and spend $700 on something else and make more power and keep the 16cm housing
Old 03-07-2006, 11:13 AM
HOHN's Avatar
Originally Posted by Phatboy
TST, Smarty, or both?
Seriously though, wouldn't it be easier and cheaper just to get the tighter housing from JR?
It's gonna be BOTH-- eventually!
Old 03-07-2006, 11:25 AM
FozSweet53's Avatar
I agree BOTH would be real nice combo.
Old 03-07-2006, 11:45 AM
if i sell some parts first it'll be comp and smarty...gotta buy tires, then smarty...and ill prolly keep the 16cm housing
Old 03-07-2006, 12:53 PM
jiMMyCTD's Avatar
so does just that one company sell the smarty? 649 bucks huh?? i smell a clutch in my near furture.. hah aha
Old 03-07-2006, 07:48 PM
Ph4tty's Avatar
I just get a kick out of it- Hohn the bombing prophet of DTR
Old 03-08-2006, 08:17 AM
97whiteram's Avatar
Originally Posted by rjohnson
FYI
RJ
RJ
So were does your "LIL"55/14 light off?
James
Old 03-08-2006, 08:28 AM
JR has told me two other truck were lighting this lil 55/16 at 17-1900rpms and says there must be a problem with my truck... im ready to take take the 55 off and throw it in the trash and do what i shoulda done in the first place and go buy a brand new phat shaft 64
Old 03-08-2006, 08:40 AM
97whiteram's Avatar
Let me know where that trash can is!!
Seriously tho......I hope you figure out your problem!!
James
Old 03-08-2006, 08:59 AM
i wouldnt sell you this POS. its my own fault, i dug my grave now i gotta lay in it even if it does cost me $1200.
all i keep hearing is there is something wrong with my truck and not the turbo
Marco's Avatar
Map?
That late spool up could be caused by a faulty MAP sensor.
Do you have any boost fooling box? Try without any box...
Check to simple things first!
Marco
Old 03-08-2006, 09:03 AM
THANK YOU for the suggestion marco...i have a comp installed. do you mean just turn it off or completely disconnect it. when i turn it off the lag is still there.
im getting my DTC's deleted this afternoon as i have the code that says my MAP is out of range because i ran around for 4 months with the map unplugged so i could shamelessly blow smoke off idle whenever i wanted. i plugged it back in but with the DTC still in the computer it may be affecting something. thats my next step tonight as i have a local guy who is gonna put the smarty in my truck and see if it helps.
Old 03-08-2006, 09:20 AM
Marco's Avatar
Disconnect the comp completly. Of course plug in the MAP!
The code alone will not defuel the truck. Try to check the codes with Smarty and see what comes up.
Quick Reply: specific smarty questions
