South Bend DD just installed...... But what the???
Installed the South Bend 3250 DD today wasn't to bad, But the truck when stopped and running and you go to engage the clutch when pedal is fully pressed it sounds like a jack hammer. Once you get to driving it the noise goes away until you stop again. Is this normal? Does that floating plate between the two discs kinda...well float? Or is it that I am in need of the hydraulic upgrade, which I thought but everyone said no. Some info would be nice plan on calling Peter in the morning. Thanks Chris
its normal.
with the clutch disengaged the disks rattle. has nothing to do with the intermediate plate. the intermediate has positive engagment to the pressure plate which it bolted to the flywheel. it can't rattle, just float.
Just wanted to let you all know that I talked to Peter and he explained everything to me on these DD. The center plate is supposed to rattle a little when you push in the clutch. To not get into a long explanation it's just kinda the nature of the beast but will help on not having excessive wear over time on these clutches. I guess the old non sprung DD were really loud from what Peter said. Anyhow thanks guys for the info and a special thanks to Peter and South Bend for the great service! A+
mine have one heck of a rattle and Vibe that can be heard well over the motor, I am un sure if the hydolics are working all the way. I am have to put the south bend kit on there.. I have the 3250 spring , they said the stock should work but I belive they need to say Just buy the upgraded ones. any else out there runing the stock hydlics with the dd 3250??
