Sourceautomotive Twin Kit
Old 09-30-2009 | 10:34 AM
CODODGE2500MAN's Avatar
I'm looking at upgrading to twins for towing and daily driving (and the occasional "wow, that's a fast, big truck ). I like the idea of a bolt on kit as I am not experienced with changing turbos or building turbo systems. Thoughts on this 2/3 system for $2500? Anyone have it? Got a better idea for a bolt on kit?
Thoughts, ideas, comments and the like are always welcome.
Thanks.
Old 09-30-2009 | 11:43 AM
Also, does this kit require it to be welded or is it strictly a bolt on kit? Is it a TOTAL Inclusive kit or are there little things I'll need to get?
Old 09-30-2009 | 01:02 PM
DIESELWRKS's Avatar
its a great set up your better off just calling and talking to Rip or Bill at source. they are bolt on kits. with certain recommendations. are you going to be using a stocker with this or do you have a bigger turbo now. just talk to them this way you get all the parts you need and the correct parts. great shop great people.
Old 09-30-2009 | 01:33 PM
j-fox's Avatar
I am running thier kit. It was an easy bolt on, using a HX-35/12 on top.
You will love it. See my sig for fuel mods.
Old 09-30-2009 | 05:26 PM
recklesskelly's Avatar
i looked into that kit to but added all the parts but the S400 individually to my shopping cart and it came out to $1600 or so. You can get the S400 from city diesel for $650 less than that if you keep an eye on ebay. I did not add the fancy powder coated cold or intercooler pipes just the ones that were welded and ready for paint. I figured i could just grind the welds and paint 'em my self for 300 bucks pretty handy with a can of spray paint.
Old 09-30-2009 | 06:25 PM
dieselman2300's Avatar
This is where I buy my S475s from.
http://www.dallasturbo.com/specials1.html
Old 10-01-2009 | 09:21 AM
See>>>>
This is EXACTLY WHY I post here. You guys are great. One member saves me nearly $250. And Bam.... another saves me an extra $65....
Old 10-01-2009 | 11:54 AM
j-fox's Avatar
Call them and figure out what is in thier kit that you haven't included.
Old 10-01-2009 | 01:41 PM
Call them for sure but I think i got it all
Twin Turbo Parts
Login / Register | My Cart : 18 item(s) / $1,593.50
Your Cart
Step 1 - Edit Cart
Product Name Description Price Quantity Total
5" Alum. Exhaust Downpipe, Jigged and Welded
Click to view
Product ID: 0407
Delete Item Remove Item
$115.00
$115.00
5" V-clamp for HT3B or S400 Exhaust Outlet
Click to view
Product ID: 0408
$37.00
$37.00
1/2" Steel Spacer plate - Laser Cut
Click to view
Product ID: 0419
Studs: 2 Studs
$22.00
$22.00
Hx35 Hotpipe to S400 Turbo with Divorced Wastegate Pipe
Click to view
Product ID: 0420B
$375.00
$375.00
12V S400 Turbo Mount to Engine
Click to view
Product ID: 0423
Year of Truck: 1997
Mounting Bolts: Yes
$137.50
$137.50
3" Intercooler Pipe with Welded Bungs
Click to view
Product ID: 0425B
$115.00
$115.00
5" Intake Tube - Finished
Click to view
Product ID: 0426C
$175.00
$175.00
High Pressure Oil Line - Engine to HT3B/S400
Click to view
Product ID: 0427-18.5
Turbo Type: S400
$35.00
$35.00
Flexible Turbo Oil Drain
Click to view
Product ID: 0428
$45.00
$45.00
12V Water Lines
Click to view
12V Water Lines
Product ID: 0430
$90.00
$90.00
Blowoff Valve
Click to view
Blowoff Valve
Product ID: 0435
$29.00
$58.00
Air Filter for 2nd Gen Twin Turbo
Click to view
Product ID: 0437
$55.00
$55.00
4" x 3.5" 4-ply Silicone Boot
Click to view
Product ID: 0438
$15.00
$45.00
Charge Air Tube
Click to view
Charge Air Tube
Product ID: 0424B
$264.00
$264.00
S400 Compressor Outlet V-Band Clamp
Click to view
Product ID: 0410
$25.00
$25.00
Subtotal Amount : $1,593.50
Old 10-03-2009 | 04:37 PM
Mike Holmen's Avatar
The Guru
Most of those prices look pretty decent. I'm sure if you look around could same some money. Are you running divorce gate? You might want to add the price of a gate into your build. Its the little pieces that drive you crazy and where to get them. I've built three set of twins now, each time you learn something new. This time a buddy built my exhaust manifold at a different angle, and did a few adjustments to my wastegate on my GT3788R. My next set, I'm going with smaller turbos to see the differences.
Old 10-05-2009 | 09:38 PM
95ram's Avatar
If you look around a little more you can find S475's for even cheaper then that. I've found them for under 500 on the net.
Old 10-05-2009 | 10:32 PM
The Guru
Turbos are the easy part of building twins, its just all the little pieces that drive you crazy. A mock-up engine is good, but sooner or later it has to go on the truck. You would have to know what you need or else you get stuck quickly.I've learnt stuff on each build that I've done.
Old 10-06-2009 | 01:21 PM
nate_88's Avatar
I called Source today and they said that I need to relocate the transmission cooler and possibly change out housings on my HX35 to fit their 2/3 kit. Has anyone had to do this?
1974d2004x4
13
10-17-2007 08:47 AM
storx
47
08-17-2005 03:27 AM
BigBlackBeast05
07-24-2005 10:47 PM
BigCarl
10-30-2004 10:15 PM
