Sound of 4" -Vs- 5" Single Straight Pipe Exhaust....??
Originally Posted by Katmandu
Where is the CHEAPEST place to buy separate sections of 4" and 5" exhaust pipe ??
http://shop.ivalueinternet.com/bigex...ry_id/1119.htm
Interesting Chris.
So it appears SOME backpressure is still NEEDED (even on Diesels.)
Turbo's typically do better with no restriction. The larger the exhaust the better, with a diminishing return as you exceed the needs of the engine. Obviously the best exhaust for a turbo engine would be no exhaust...
The reason why a NA motor requires exhaust, is due to the pulse/scavenging effect. Something that a turbo takes care of on the cummins.
I'd be surprised if 5" hurt performance CTD unless you're running some outrageous turbo and in need of a 6"
Here is a video of my truck........it has 4" turbo back w/ no cat or muffler and a 5" tip. I freaking love the way it sounds.
OH AND BY THE WAY, don't pay attention to that 1/4 mile time, I was playing with my COMP box and boost launches and that run was HORRIBLE but the only one my ex wife managed to get on tape..........go figure
Clicky click
~Nick
Clicky click
~Nick
[QUOTE=No they dont want back pressure, the reason a 4 inch will run better till about 550 is the air will pump more efficiantly out that size tube. a 5 inch does not keep air speed up well enough and will hurt the performance till you cross the magic 550 hp threshold.[/QUOTE]
Im still running the factory downpipe (saving money for a megamouth). Tried the straight pipe thing and felt it was too loud for my taste; do not want to disturb others at the campgrounds. So my question is how will the above affect me if I run a modified factory cat no muffler and 5" out to infront of the rear wheels.
Originally Posted by 2500CTD
So how much would a 5" tip change the sound? I have Rips 4" and I'm thinking of a 5" tip on the straight piped 4".
I have a five inch straight pipe sitting behind a 4inch downpipe. I used flex pipe to get over the axle, not the prettiest but works fairly well. I loved the sound, my buddy has dual 4 inch and his sounds amazing. Mine is loud and sounds great but my buddies dually just sounds better in my opinion and he doesn't have as much interior sound. He thought his truck was quiet because he never was outside to hear, but it was loud as hell.
''larger or exhaust tip in general does nothing to the sound.''
I'll have to disagree with that just a bit. Look at a trumpet in a marching band. There's about 27 feet of tubing in that thing, and all the same size...untill the bell. It's only the last 4 inches or so of that 27 feet, but without it, there would be almost no sound at all. I do agree that it's easy to mess up a tip and make it look 'ricey', but done properly they look fine and can have a very plesant effect on the sound. JMO.
Originally Posted by rebal
my sons 5" is a lot deeper then my 4" ,both are strait piped
Any 2,000 RPM drone out of either of them ??
I am not sure where you could find the cheapest price for some pipes..I've got inside connections at work and got two 8 foot long 5" diameter pipes for free and fab'd up my exhaust off of that. I'll probably do the same thing when I put stacks on my truck
Well I'm not positive on this but hear me out.
When your under a certin HP rating lets say 500 for this discussion going to a larger pipe may cause you to loose HP and here's my thinking on this.
4" pipe obviously is smaller so the amount of air moving through it @ 500 hp would be a smoth flow v/s changing to a 5" and causing the exhaust to stall in the larger pipe. Look at it like a river, durring its travels through a narrow canyon its moving fast and the edges dont have much turbulance then when it gets to a wider area the same amount of water is still there but it moves way slower and the edges have turbulance, water swirling around etc.
Air flow would look the same.
Now truthfully I doubt going to a 5" pipe is going to create any problems like maybe a 8" pipe would. Our little 5.9 ltr's move an amazing amount of air.
After I read back through this I'm guessing with the amount of air we are stuffing through our engines that even a stocker would be ok with a 5" pipe.
Anyone else have input?
Dan
Dan
Ive got a 5 inch system on mine and I love it. I have a 4 inch downpipe then at the end of the downpipe it goes to 5 inch. All my buddies say it sounds like semi. A little louder that a straight 3 or 4 inch but alot deeper meaner sound. I didnt notice any more cab noise though. I bought mine from Marty's Muffler Mart in Rolla, Mo. I think the brand of it was Flo-Pro, it came with a muffler but I had him just put a piece of pipe there instead. With all the pipe, a 5 inch stainless tip, and labor it was around $640 installed. Go ahead and do it, you will love it. Couldn't tell a difference power wise from a straight 3 inch system. Im sure it helped my EGTs a little too.
I want to know how a 4" or 5" straight exhaust the exits BEFORE the rear wheel sounds.
