Solid Steel Trackbar
Has anyone got the new second gen trackbar on their truck yet??
http://www.solidsteel.biz/
Any opinions??
Any opinions??
I have both the DSS stabilizer brace and the 03 track bar and I am still having trouble not chasing sheep down the highway. It looks like the rubber bushing has softened up a bit, I am getting tired of this front end and looking at a manual locking Dynatrac 60 and new steering box. PK
Classic 2nd gen
Dss Track Bar And Brace
I have both and they have worked wonders, I actually have the adjustable track bar as I am leveling the front end this winter. IMHO definitely worth the money. I had the steering brace isntalled after replacement of my third steering box by DC. Havent had a problem since.
Dave
Dave
The DSS helped mine a lot, probably saved the steering box. Now, I need to replace the tie rod end on the pitman arm.
I put a Moog Trac Bar on really worked good at first, now two months later it needs replacing. It's a lifetime warranty item, just not a lifetime solution.
Hmmm...where have I heard this before?
Hey so im new to the whole traking bar thing can you guys fill me in? My truck drifts to the right REALLY BAD as in so bad i can exit the freeway by letting go of the wheel and my tire is shot on the right outer edge. If this was an IFS thing it would be EZ to fix I dont know how to fix these, im guessing the tracking bar is shot right?
Any opinions??
Any opinions??
I have been checking it closely due to comments from Cowhand & others that the bushing will probably not hold up.
So far...working well!
Was unaware of the Thuren Trackbar option when I did mine. It appears to me to be as good...maybe better, than the 03 trackbar....and less expensive.
RJ
I have both the DSS and the 3rd gen track bar. They both made an improvement. The DSS was no question a great upgrade. The 3rd gen track bar well cant say for sure, at least yet. While it did improve it should have my old one was shot. Test will be if it lasts longer and when it does go will I be able to find new bushings to rebuild it on the cheap. So far I have about 45k on it and it still seems good.
Cowhand, what do you think of the new Solid Steel trackbar compared to the Thurenfab bar?? Hard to tell if you havent ran it - but, any thoughts??
