software #0. any one try it for long??
Old 03-23-2006 | 06:49 PM
duallydave's Avatar
Talking software #0. any one try it for long??
hey guys,i tried software 0 to see if i could get any better milage and could only stand it for 1 day then it was back to #8 with the comp on 3/3{seems most reponsive without excess smoke}if software 0 provided some serious fuel gains i mite be tempted to leave it on for longer.i tried software#1 and it seemed kinda noisy,maybe to much timing??.i totally recomend trying #o for awhile then #8 or 9 seems crazy. haaahaaa
Old 03-23-2006 | 07:05 PM
Bob Wagner's Avatar
the software is only good for one thing. NO SMOKE WHEN YOU NEED IT
Old 03-24-2006 | 02:37 AM
Ph4tty's Avatar
I went to 9 to 5 to 7 to 1 in the 1st day then to 4 then 7. I haven't tried 0. I'd only turn that on if I were to line up against Dually Dave =P
Funny thing is mileage has improved with every tank.
Old 03-24-2006 | 09:05 AM
duallydave's Avatar
Talking
sure ill put my truck on software#0 against yours on software#0 anyday,hahaha, a race of the slugs
Old 03-24-2006 | 12:10 PM
Andy505's Avatar
That could be quite interesting.
Old 03-24-2006 | 12:59 PM
jazz_kt's Avatar
I have an hour glass to time you guys in the quarter mile. Maybe even have time for a couple cold ones during the race.I bet the amish with the horse and buggy would be a heck of a race.
My money is on the horse and buggy
Old 03-24-2006 | 03:25 PM
HOHN's Avatar
I'm running #0 right now, and have been for a month.
I'm doing this to try to delay (not eliminate) the replacement of my clutch. You get used to the low power eventually.
Even with 150hp injectors, I can't MAKE the truck smoke! None!
Lord knows I miss #9 in the worst way. But I can't chance a severe glazing of the clutch and having to TOW my truck to the trans shop, instead of drive it.
Finding a competent clutch installer here in Tampa has been endless frustration, and I need the time that hopefully the low power is buying me.
I think with #0 and Mach 4s, I'm slightly UNDER the original stock HP rating.
Unfortunately, SW#0, still gives you a lot of gain in the idle governor circuit, so even though the engine is gutless, it WILL give you a big fight in resisting speeds below idle.
What this means is that if you pop the clutch in 1st gear with no skinny pedal, SW#0 will give you just as much oats as SW#9-- at least it appears to. Once idle RPM has been achieved, the power disparity is what you'd expect.
So even though SW#0 will make low dyno HP, it's not necessarily that much easier on the clutch in slugging.
As for 1/4 mile times, I'm pretty sure that SW#0 has me putting down solid 19s or worse. Can't imagine what it would be like with stock injectors!!!
jh
Old 03-24-2006 | 03:50 PM
Bob Wagner's Avatar
justin running around in #0 shame on you
tatkins85
07-28-2008 12:17 PM
taken5875
13
11-14-2007 10:52 PM
crankbender
05-30-2007 03:47 PM
sandpuller2004
09-02-2005 12:58 PM
