Snow Methanol ???
Snow Methanol ???
Who has tried the snow Diesel Stage 3 MPG-MAX™ Boost Cooler does it really make a difference when towing to help keep the EGTs in check? and with millage? or with performance? any opinions please chime in.
I have a two stage Snow and tow 26k lbs with it.
I'm running 100% -45 washer fluid.
I have the 1st stage set to kick on a 15 psi 2nd at 25.
It works very good, drops egts about 150* instantly.
Didn't increase mpgs or performance as far as I could see, just keeps me in a higher gear and speed, which probably counteracts any gains.
The Guru
I picked up 70rwhp on a dyno running a stage 2 snow kit. I was just using one nozzle with an adjustable controller at the time 18 start and all in by 30.
I've run my system for three years now, without shutting it off. It works pretty good, except when the engine is cold
My turbo looks like brand new and my head isn't cracked. Prior to the water/meth, I had three heads crack, right between the intake valve seat and exhaust valve seat.
Red3quarter
12-12-2009 11:12 PM
stroker4501
01-12-2008 11:37 PM
jmccart
05-28-2007 06:53 PM
