Smoke Box and bed liner.
Will the smoke box heat up enough to damage the Rhino lineing?
Do I need to weld a chunk of angle to the box as a heat sheild?
Howmuch bigger does the hole in the bed need to be than the feed pipe for the smoke box?
Do I solid mount the smake box to the bead so it doesn't move or is there a way to account for flex?
If you are asking about a stack, then no it won't hurt it from what i've seen. I've had one on for three years and the paint around mine is fine and my stack is sorta resting/wedged in the hole I cut in my bed.
darrylmueller
03-17-2013 07:42 PM
CZSteve
03-08-2011 08:11 PM
Clane
05-09-2009 02:50 AM
04ctd
02-18-2005 05:30 PM
