Smarty or XZT+ and....
Old 03-05-2008 | 09:28 AM
hamilton71801's Avatar
Originally Posted by high bid
ok thanks for all the info!!! But then what does the xzillaraider do that the schip doesn't? the schip adds timing & fuel. If I stack the xzill with it won't it add too much timing?
I wasn't really planning on tapping the pump right now.
I think the SC is a timing only programmer.
Old 03-05-2008 | 09:30 AM
GFB's Avatar
GFB
superchips is mainly timing, and a little more aggressive fuel map. the xzillaraider is a fueling only box via the wire tap. you have to have a wire tap to make more than +65hp. the xzillaraider is a 120hp fueling box.
Old 03-05-2008 | 11:43 AM
high bid's Avatar
If all correct above, like you said, I could add a boost fooler, keep the schip stack the xzillaraider and new 1.6 injectors and have a killer setup or would the 1.6s provide to much fuel w/the xzill. sorry for all the questions and thanks for the help/clarification.
Old 03-05-2008 | 03:12 PM
GFB's Avatar
GFB
You shouldn't need a boost fooler. That would be a decent amount of fuel for your HX and a lot of fun for playing around, maybe a little warm for towing. Good thing is you can turn the xzillaraider down/off for towing so you don't have to worry.
Old 03-31-2008 | 11:29 AM
high bid's Avatar
thanks for all the input. How does one go about getting the ECU reflashed to return to stock? In order to install the XZT+ I have to do this and don't have the schip programmer.
Is this something dealers charge for and can easily be done?
Old 03-31-2008 | 01:09 PM
Take it to the dealer and have them flash it...of course they will charge you 1 hr shop time so you might be able to do it for under $100.
Old 03-31-2008 | 03:26 PM
NoSeeUm's Avatar
For about the same money as 2 new XZT+'s you can buy 1 new Smarty. I have tried both, the Smarty has better performance. The Smarty also condenses the throttle pedal and causes a whole lot more smoke. The Smarty can do tire size adjustment and speed limiter. The XZT+ does high idle warm up. The Smarty software has rarely been updated, the XZT+ gets constant attention by Quadzilla with many updates to choose from.
Really its a toss up. Consider better performance with the Smarty trading on the fly adjustability and a huge price difference to the XZT+.
Jim
Old 03-31-2008 | 04:07 PM
high bid's Avatar
Thanks for the 2cents...already purchased the XZT+ now I just need to figure out how to get the ECU cleared/reflashed so I can install it. My priority for the upgrades has to deal w/being able to tow without 2000deg egts.
Old 03-31-2008 | 08:04 PM
NoSeeUm's Avatar
LOL That's me a day late and a dollar short.
Give Bob Wagner a PM or a call. I am only guessing he could help you out.
Jim
Old 04-01-2008 | 09:10 AM
high bid's Avatar
no worries, thanks for the input.
I did notice that someone said to disconnect both batts, turn the key on for 30sec and then touch the pos & neg lines together. This should clear the ECU and return it to stock....can anyone confirm this? It beats going to the dealer and serving them a $100.
Old 04-01-2008 | 10:39 AM
All that might do is clear any codes you have but I don't see any way it'll re-flash the ECM. You'll either need the original SC or take it the dealer.
Old 04-01-2008 | 08:37 PM
NoSeeUm's Avatar
Hamilton is correct, it will not change the ECM. I would contact Bob before I contacted the dealer.
Jim
Old 04-02-2008 | 09:19 AM
high bid's Avatar
Jim
Doesn't he work for Smarty? If not, then I have him mixed up w/someone else. Can you post his user name so I can send a PM? thanks.
Old 04-02-2008 | 01:13 PM
NoSeeUm's Avatar
Yeah he is the Smarty guy, but also fairly well known as an ECM Guru. My only point in suggesting him at all is that he might save you some $$.
Jim
Old 04-02-2008 | 03:07 PM
high bid's Avatar
So can you send me Mr."Smarty" pants user name/or ph #. No pun intended.
