Smarty On The Way
Being that you have an EZ already, you're not going to see the gains that others did when coming from a stock truck, or atleast a boxless truck. Its not gonna add another 65hp on top of what you're getting from the EZ already.
I love my Smarty!
Presently my overhead shows 23.3 mpg on #3 setting(usually less than 1 mpg off)As long as it's warm out that seems to be normal for about 50 mph commute.
The clutch seems to be suffering a bit lately from the higher settings but boy are they fun!
I would sell the edge ez and get a TST MP-8 fueling box or something similar. You don't want to stack two timing boxes together really. I doubt it will cause transmission problems. But you should atleast put a valve body and TQ in that transmission. Stock auto with any mods or stock truck towing heavy you will have problems.
Wow Just Plugged In The Smarty And Even Tho There Are No Signifigant High End Gains With It Compared To My Edge Ez I Can Really Feal The Low End Power....so Far Im Xtremely Pleased With The Smarty
Ya The Code Reader Is Awsome Found Some Codes In There That Werent Showing Up On The Self Diagnostic Run You Can Do....i Also Did The Abs Adjustment Didnt Have Time To See How That Worked Out But I Will Find Out On My Way Home From Work...not To Mention The New Throttle Response Is Pretty Kick @$$
I like mine most on #3, all the other softwares make the pedal ultra sensitive, you push it a bit too far and you get less instead of more throttle.
great programer but just don't expect any updates or fixes... ever...
I Got Mine On #6 And Love It I Got To Run The Even Numbers Tho Bcus I Got The Edge Ez And I Dnt Want To Over Do It With The Timing That The Odd Numbers Change
stock03
34
04-21-2011 07:40 AM
600 Megawatts
26
07-14-2005 06:04 AM
