smarty stack?
smarty stack?
i've been thinking about a smarty i've heard they give alot of power down low cause right now my truck doesn't come to life until 2000rpm will this help my spool up and reduce some smoke
It will help out on the bottom end and spool up quicker but the stack will provide the opposite effect as far as smoke goes, much more of it but that's a good thing, right?
smoke is alot of fun when you can control it but when your trying to get a trailer rolling uphill its kind of a pita plus it draws attn that i don't always need
a smarty is great down low i tow with mine on level 3 and with a htt 64 charger i have no problem cleaning it up i mean well i can clean mine up with it on 9 so id say if you put it on 3 and leave your juice turned off you will do great
i love the adrenaline smarty stack. it fuels so hard. just be sure to hook up the egt probe for the adrenaline and update it to where it defuels at 1250*. with my stock charger the pyro was moving as fast as the speedo. the update does a nice job defueling so it dont get too hot.
smarty
I really enjoy the smarty with my TST. since the revo has came out alot of custom tuning and playing around to find what your looking for. with my 62/14I dont have a smoke problem only if I want one. you will enjoy it. nice to clear codes and change things so easy when you want to.
2002 HO 6-SPD LB 4X4 QC HTT 62/14 SB-FE TST PM3/*REVO-BETA*SMARTY MACH 4'S, RINGED AND STUDS, AFE/2 " 4"EXHAUST D/PRICOL GAUGES, FASS 150, VULCAN 1/2 DRAW-STRAW, 3/8 FUEL LINE, DSS-TRAC-BAR STEER-BOX, AIR BAGS,17'' KMC BLACK HOSS, 315/70/17 MICKTHOM MTZ'S 6" RCD LONG ARM LIFT. :-laf...THANKS RIP WWW.SOURCEAUTOMOTIVE.BIZ
I've noticed with my Juice that she really backs off on the fueling between shifts, so the Smarty will keep fueling, right? Isn't that really all the torque management is? My Smarty is in the mail, just looking for a heads up here.
I had borrowed a smarty from a friend and we had just put a set of 200+ injectors in my ride, i wasnt so sure it could be that responsive! but what can u expect w/ a stock 35 turbo equipped w 200+ injectors, a comp on 5x5, and the smarty on the highest tune w timing?! it accellerated like a... the thing ran good!
Topper
03-03-2008 10:17 AM
white250005
10-25-2007 10:19 PM
B.Law
16
04-22-2005 02:28 PM
Cat Cracker
07-14-2003 12:17 PM
