Smarty Issue
Smarty Issue
When I plug my smarty in everything comes on ok. But when i try to connect to the truck ECM the Smarty displayes (no stored DTCs). does anyone know whats causing this or has anyone had this problem?
Sounds like you are clicking the wrong number. You want to go into ECM/ABS Update and not Read DTCs or whatever it says.
I just got mine as well and everything is working good.
Like Dinner is sayin.. sounds like your clickin the wrong number, insted of hittin DTC/ABS hit number 1 For ECM Connection.... Just sayin but if you want a good stack on for your smarty, the edge juice is awesome, just make sure you only run your smarty on the even number softwears
I already have the edge Juice stacked on it, and i do like it alot. but i have tried pushing the number 1 button for ecm update and it still goes to the "no DTC stored" and i have tried pushing every button and they all go to the screen sayin "no DTC stored"
dan123dbl
02-13-2015 05:47 PM
stock03
34
04-21-2011 07:40 AM
