Smarty Gains
![Question](https://www.dieseltruckresource.com/forums/images/icons/icon5.gif)
Approximately, how much will the smarty box alone gain in HP/TQ on a stock 2001 Sport (non HO)?
How much more If I add the 275/RV injectors?
Thanks,
Dave
Thanks,
Dave
The smarty will add 65hp and the 275's will add around 40 hp. Most people that run the EZ/275 combo dyno real close to 300hp. So since the EZ and the smarty net the same peak hp you would also be around 300hp with the smarty/275 combo.
Jamie
Jamie
Wow! I thought the smarty would put down more than that!? I guess it's just better than a EZ and maybe a few other fueling boxes because it fuels harder down low and no need to do a wire tap(unlike the comp and soforth). Is this correct?
The way the smarty fuels and adds timing is what makes it so desireable. The smarty can makes overall drivability much, much better...
So what is the process of switchin to a different. I know you have to download it or whatever. Do you just plug it in and do it from there or do you have to go through the whole computer process again?
Impressive
Smarty gained 76 hp on a back to back dyno test this past weekend; 24v with an HRVP-44 and Jammer 2 injectors......
https://www.dieseltruckresource.com/...d.php?t=127223
RJ
RJ
