smarty/drag comp stack??? im confused
if i stack this unit with a drag comp....can i use the smarty all the time and turn the comp off and on at level 5x5 when i wanna pull or race. but id like to have the timin in with the smarty. if so can i run the drag comp on highest fuelin level to get the fuel and let the smarty bring the timing?? that way i could run the smarty on the highest setting all the time and bring in the top end fueling when i want it without the added timing from the drag comp.
does that make sense to you??
i want the most from the smarty for daily drivin and use the comp only when i wanna play. using the settings without timing on the comp instead of the settings on the smarty without the timing(even settings). more or less only using the comp to add the top end fueling??
Most peolpe dont relieze how stacking chips work. For example you have a 100hp edge juice and 100 hp bully dog stacked you are not going to 200 hp you have to find the proper stages on each chip which makes it run the best. For example edge stage 4 and bully dog tow that might be the right combo. You put both chips on the highest you will probably not run that great.
LittleRedWagon
16
09-10-2008 12:36 AM
dieselbeef
34
08-17-2007 03:26 AM
dodgediesel
07-27-2007 09:59 AM
MoreSmoke
01-07-2004 10:40 PM
hellotbone
18
05-16-2003 05:40 PM
