smarty drag comp stack! holy crap~!!!
The only reason i want a smarty is because of the higher rpms before de-fueling. But someone told me i just need to send my edge comp in for a re flash or something to change that. if thats the case then i think that may be better. I only use the truck on weekends it seems like to tow the boat or the cruiser around... input is needed ASAP!!!!!!!!!!!!! hehehe.
thanks, jiMMy
thanks, jiMMy
While the Smarty supposedly gets rid of the RPM limiter, I made more power at the higher rpms with the Edge products. On the dyno, the Smarty would not run to 3100 rpm. That's a dynojet, foot to the floor, it just stops revving. The drag comp took me to 3500rpm under the same conditions.
Dave
hmmm, so only on leval 5 huh. i dont tow on 5 so i dont think that would benifit me much??? not looking for peak HP as i dont think i have even floord the truck yet. just want to carry a gear a lil more before shifting while towing to the lakes and the trails and not have it peak....
I think they advertise 60Hp or so. But I have no idea on what vehicle that would be figured on. Obviously, ability to stack it is what's nice.
Dave
Dave
I had mine delayed to 10 psi and hated it. Changed it to 3 psi and it really worked well. In fact, I am selling that TST. But, you may wnt yours setup a bit differently
The nice thing about the TST and other external boxes is they look for some boost before fueling. I am still running the TST with the stock ecm. Works great! With an EZ, it flat rocks.
Dave
Dave
Yeah; I am with FtD4U here. I have thought about having my TST re-programed for 5-10 psi. 5 psi is about my smoke threshold. I talked to TST about it and they reccomended just leaving it at 3 psi. It is easier to just turn the TST down. According to TST, on all levels the TST will start fueling at 3 psi. From my experience the ramp up rate is scaled slower at the lower levels and corresponds according to what level the TST is running at as well as the maximum fueling rate (fueling solenoid duty cycle).
IMO if you have it set for 20 or 30 psi you will likely be in the market for a new turbo pretty soon. It spools hard enough from 3 psi, but still gives the wastegate time to react before overspeed. With the TST on higher levels the fueling is fairly harsh and the spool is off the chart fast. Take that last comment to the bank.
Currently, I am running stock SW TST3 even for my light towing jobs. Power is very smooth with little smoke. Like FtD4U (was doing), I am using the TST to set the rpm rise when unloaded over the Smarty SW alone. TST6 is very nice and TST9 still nicer when I am feeling froggy, but TST3 is the normal these days. By tommorow that will likely change.
I tried running Fuel Saver for a bit as smoke was down over stock. In the end I like more quiet at 2300 rpm grinding up a grade. I also worried about the wear and tear on my engine long term by fueling too hard, running higher boost and lots of timing. So I put it back to stock. My mileage may suffer.
Jim
But basically, all odd SW did 50-60 Hp and the even's did 20-30 Hp. They did not show the torque curves for Hohn's "Area under the curve", only the numbers were posted. I don't remember the torque numbers.
Jim
Smarty Test's
Here's some test's we did with the tow truck that only has light mods, like Mach 1.2's and 5" MBRP. But not stock http://www.competitiondiesel.com/for...ad.php?t=10045
Thanks Brett
Thanks Brett
My dad's '02 auto stock except 4" rips exhaust with muffler and BHAF.
42 HP over stock. Dyno'd within 1 Hp on levels 3,5,7,9,. Even levels only made 18HP.
Dave
Dave
Hohn;
Jim
Jim
So if maybe I should run the standard ramp up but have it set for right one the turbo starts to spool-- say 5psi with a small turbo, or 10psi with a bigger charger like the 71-series HTT or the SPS units.
Thanks for the advice on this...
JH
I tried lowering the levels on the TST to see if the EGTS changed but nothing to drastic
To bad that the JVDs are defunct for the most part (hard to get)
And now I have it stacked with a smarty
Heck yes.
For the longest time, I was afraid to tap the pump wire.
But time has proven to me that tapping the wire has no measureable, consistent effect on VP durability.
I lost a VP at 40K miles with good FP and no wire tap.
Good FP is not a guarantee of VP life.
Not tapping is not a gurantee of VP life.
So what *IS* a guarantee of VP life? As far as I can tell, nothing is. The best you can do is feed the FP with a consistent supply of cool, CLEAN fuel.
After that, I think VP life is up to lunar alignment or Karma or something else.
I'd pray about it, but I'm convinced God cares about my soul not so much about my VP
Watch for major truck changes this fall- perhaps dual spinny things.
jh
jh
