smarty/comp.anyone dyno yet?
Old 03-05-2006 | 10:49 AM
duallydave's Avatar
Talking smarty/comp.anyone dyno yet?
has anyone dynoed thier smarty with and with out the comp?without the smarty my clutch was pretty muchmaxed out and with the smarty on #8 it slips in 4th and 5th quite easy,it also feels in the sop meter that its more than the 60hp its claimed to be,could it be that on a stock truck it provides 60rwhp and the more mods the higher the hp gains?my clutch is crying a river.
Old 03-05-2006 | 12:41 PM
AggieJustin's Avatar
Based on previous reading about mixing the Smarty with another fueling/timing box, you probably won't see as huge of an increase on the peak number, as that's not where Smarty works all of its magic. The Smarty gives you a much bigger kick on the low end, so the thing I'd be looking for the on the graph is a sharp upward path to peak in the lower RPM showing that the power is coming on much earlier/faster.
Now if you have a larger turbo that is normally slow to light on the dyno, the Smarty may be just the thing to get it lit sooner which should translate into higher numbers.
Old 03-05-2006 | 07:44 PM
White00's Avatar
I don't know what the smarty is rated at, but with the old school special catcher and a comp I did 315 and 774. That was with stock injectors and turbo. This might give you a ballpark idea.
ADAM
Old 03-05-2006 | 09:34 PM
duallydave's Avatar
wow im a little surprised,i figured a comp and a mad ecm would make 350-375hp and with some injectors easily go over the 400 mark.any one else dyno with a comp and a mad ecm or a smarty?
Old 03-05-2006 | 10:39 PM
Bob Wagner's Avatar
I will hit the dyno in the next week or so. My last dyno wa 401 with software and mach 4's only.
we will get more numbers from differnt set up's
Old 03-13-2006 | 11:41 AM
CTD_Neil's Avatar
Any more updates on Smarty/comp dyno numbers?
Old 03-13-2006 | 02:11 PM
Diesel-Dan's Avatar
BigBlue just dynoed this weekend with a Comp and Catcher (if he still has it)......soooo....im sure its a matter of time until he sees this thread......
Old 03-13-2006 | 03:49 PM
HappyGA's Avatar
Big Blue has a thread in the Competition forum, and he laid down 398. But he is also running a DTT valve body and a KSB-1 turbo. SO he is a little past the comp/Smarty combo.
Oh yeah, he was dyno'ing with his air conditioner on. Guess he likes to be COOL while showing off.
He mentioned that his tranny was prolly holdin back quite a bit of power. since it is all stock except the VB.
Old 03-13-2006 | 04:12 PM
Diesel-Dan's Avatar
ha! Last Dyno we went to at Redline....he did the same thing! haha.....Dumb Donkey! HAHAHAHA
Old 03-14-2006 | 12:43 AM
Ph4tty's Avatar
I'm just waiting for the smack down now
Old 03-28-2006 | 10:37 AM
CTD_Neil's Avatar
Anybody else dyno'd with comp+smarty and comp only? DonM did you ever make it back to the dyno with your smarty?
Old 03-28-2006 | 10:52 AM
BigBlue's Avatar
Sorry yall, I didn't have the catcher on for my dyno. I figured that I was going to be stressing the trans enough just by turning the comp up. Come summer time I'll have a trans and a smarty so I'll most definately be back on the dyno.
Old 03-28-2006 | 10:56 AM
CTD_Neil's Avatar
Thanks Blue,
I'm just curious to see if a Smarty would improve my dyno numbers any. I realize the smarty is designed for down low power and driveablity and it does it well. Since it helps spool my turbo faster I wonder if the increased torque down low would be enough to raise HP any?
Old 03-28-2006 | 12:13 PM
BigBlue's Avatar
You might see a small increase in peak power but peak power is not what it's all about. Look at the power under the curve. Do a run with the smarty off and then one with it on and I'll bet that you get a HUGE increase down low between the two runs.
Old 03-28-2006 | 01:51 PM
Diesel-Dan's Avatar
...just remember to shut off your AC!
