Smarty and boost
Smarty and boost
I don't know about you guys but with the smarty on sw#6 and box off i can hit 38 psi on the guage, and in a hurry. I turned the box on to see what I could get and on 2x3 i can easily hit 45 psi. I know thats way more than the little Hy can handle, but i mean it is crazy. Also the tranny shifts much smoother now. This Marco is a genius.
#1 question would be where is your gauge plumbed in to?
#2, I've watched trucks hit those kind of numbers with stock turbos, only problem is they were HX-35's..... how are you getting 40+ out of an HY?? and how high are your EGT's??
i can hit 40+ lbs with just my drag box on 2 / 2 and mine is plumb in to the intake it will get higher if i turn up the box but whats the point after 45 lbs you loose power any way. and who looks at that egt gauge anyways
I don't know how i am getting 40+. maybe its the air out here.
I realize it is out of its efficiency range when that high. I have
noticed egt's run about 200 degrees hotter now.
Originally Posted by PHD_WHITETRUCK
.... after 45 lbs you loose power any way. and who looks at that egt gauge anyways
And over 3/4 throttle...I drive, soley, by my EGT gauge.
TWODIESELS - no difference, as I understand it, between power with Smarty on #4...#6....or #8. Just comes in a little slower! It's not like your comp box with less fueling on lower settings. So your boost SHOULD be same (with comp off) on all three settings??
AND I agree with you. Marco is a genius.
RJ
stock03
34
04-21-2011 08:40 AM
vwjunkie53
19
11-09-2007 03:27 PM
RockcrawlingTJ
07-22-2006 06:11 PM
GTSDave
07-08-2005 10:06 AM
