Smarty!!!!!!
Smarty!!!!!!
Well, after the ninja postman somehow eluded me, I went and picked up the box I have been waiting for at the post office. I plugged her in, loaded #5. I was like I was impressed with the throttle response and the little cloud of black smoke. I pulled over, and two minutes later I was on #9 --Full Catcher. I couldn't keep the tires from spinning on the wet pavement! The throttle response is pretty unreal and it builds boost right now. I also enjoy the clouds of smoke she puffs out.
Next I changed the tire size in about 30 seconds, and then loaded up sw #1, fuel saver. Took her out on the interstate, and I was very impressed with the numbers I was seeing on the overhead display. I won't give figures until I can confirm the accuracy of the old overhead milage. I was also quite impressed with the throttle response in fuel saver-I wasn't expecting that!
I read codes, and had two: P1492 - Ambient/Battery Temperature Sensor Voltage Too High and P1693 - DTC Cleared in JTEC Companion Module
If anyone can tell me what these mean, I would appreciate it.
The sensor must be going bad.
phox
stock03
34
04-21-2011 08:40 AM
RyeThomas
40
04-20-2007 11:12 PM
CTD_Neil
02-23-2006 10:27 PM
