Smarty
Smarty
No I have the smarty and was just curious of the amount of timing each chip does. Does anyone know why when I have the smarty on 4-8 with the hot juice on I like lose power until I let off the throttle. After I start backing off the truck like takes off.
I've run the Smarty odds with an Edge EZ, not too bad. It had some timing rattle, but it wasn't bad. You can only get so much timing via the electronics from my understanding. The only other way is to use a different key number in the vp44, like what the HRVP uses.
That's just a smarty trait. From what I've gathered it's because he compresses the throttle so when the pedal is on the floor it's reading say 120% and it doesn't know what to do. So when you back off your back at 100% and the truck knows how to add fuel. I know that's a very rough, horrible explanation but it's all I can think of after 2 hours of accounting homework.
stock03
34
04-21-2011 07:40 AM
RyeThomas
40
04-20-2007 10:12 PM
CTD_Neil
02-23-2006 09:27 PM
