smarty
Old 10-18-2006 | 11:49 PM
Teamropinram85's Avatar
Question smarty
will my truck smoke still with the smarty like it does with the comp box?
Old 10-19-2006 | 12:14 AM
kelownadiesel's Avatar
no way.The smarty does not tap the pump wire.No reason why you cant run both though,thats what Im doing.Just dont mix timing softwares,run the comp on 5 and the smarty on even number catcher software,prefferably 8.My truck will smoke like crazy before boost if I want.Its a good combo.I leave the comp off for normal driving and then turn it on if I gotta beat some ford
Old 10-19-2006 | 12:39 AM
Ph4tty's Avatar
If I hit it hard enough at a low rpm I can smoke enough to make a freight train jealous pretty much as long as I want to
Its not hard to drive it clean too.
Old 10-19-2006 | 11:19 AM
redstreak's Avatar
In a low RPM range stacked with the Comp it'll make a world of smoke. The Smarty makes our VP44's fuel like a dang P pump on bottom end.
stock03
34
04-21-2011 08:40 AM
RyeThomas
40
04-20-2007 11:12 PM
BigBlue
11-22-2006 03:46 PM
bnold
39
06-04-2006 09:21 AM
CTD_Neil
02-23-2006 10:27 PM
Quick Reply: smarty
