Smarty=not impressive
Just don't go sliding off any mountains and breaking more than a mirror! The shipping on some of the bigger pieces will be crazy!
Take care of yourself!
There must be something else up with your truck because I can pass any Chevy I want pulling a Ford. I have more mods but still the smarty should really be noticeable on the low end. Oh well 99.9 % of smarty owners are very satisfied. Nothing is 100%
Doubtful there is anything wrong with my truck. It is just as fast as a friend's 4x4 QCLB with stage 2 injectors with the comp turned OFF. I have driven and ridden in a CR truck with a smarty and I guess my hopes were just WAAAAAAAAAY too high for the 24v smarty as it did not feel 1/3 as strong as the CR. My point is that I am not willing to spend $650 on something that I barely notice so I am glad I went and tried one before I bought it. The good reviews on a smarty is most of the reason I bought a cummins. I guess Im just sick after riding in an 04 dmax with a little superchips which made it scream.
if youre afterhigh horsepower numbers, why did you try a programer with the lowest power gains. obviously a 120 or 180 horsepower gain is going to be more noticeable than 60-65 horsepower on a 7000lb vehicle. stack the smarty with a fueling box and or injectors and you have one screaming machine.
I also have never seen anyone say that the Smarty makes more power than the comp box. What I have seen is those who own one love it, myself included. My Smarty on level 9 makes a huge difference, maybe you are expecting a bit much from a truck designed to be a working truck vs the current feminized, grocery getting offerings from the big 3 today.
The new trucks make alot more hp for less money, that's just how things go, if that's what you want then go buy one and quit whining.
I just noticed that you said you rode in a CR truck with a Smarty, you do realize that the Smarty for the CR trucks make 180hp vs the 60hp on a 24V? The reason is, they are way more computer controlled and can get the power easier. You can make a 2nd gen fast but you have to add a lot of things to them, boxes, injectors, turbos etc. whereas you can buy one box for a CR and make it just as fast. Just the nature of technology today. To me going a buying a brand new truck just for that is not worth it when my truck is paid off.
If I had the $$$ for the other bombs necessary I'd stack a TST module with the smarty. I think that the smarty timing is really spot on and much more intelligent than the stock timing advanced by xx degrees like the fueling and timing boxes do.
As for passing power- I can hang with the VW Tuareg on those roads- the V10 diesel that is. I couldn't pass it (no way to do it safely) but it's not bad for a 7000 pounds truck.
AlpineRAM
I don't think I have ever read about anyone saying that the 24V 2nd gens were faster than the CR trucks. In fact I'm pretty sure everyone knows that the 2nd gens in stock form or close to it are going to be slower than all of the big 3's current offerings. That's because the industry has made huge strides in the last few years making a diesel perform more like a gasser, in fact if you compare dynos from a 24V or 12V vs a CR motor you will see that while the 2nd gens will hit max torque very low in the rpm range the CR's don't hit it until much later, which makes the CR's great for speed but IMO not as good pullers or workin trucks.
You could try the smarty with a set of Mach3s.... Well I'm partial to them, but my rear tires told me they hate this combo
The CR engine has much more that can be gained by electronics (and software) tickery than the 24V - it's in the injectors. With the 24V the injectors can't be forced to flow much more than stock within reasonable time.
AlpineRAM
AlpineRAM
If you want to keep up with CR trucks, you should have bought a CR truck. I wouldn't have bought a Smarty if your wanting lots of power. That's why I have a COMP Drag box, injectors, turbo, etc. The smarty is just for low end power improvements. You can get plenty of power out of your VP44 truck, but you need the right combo. A smarty on a stock truck is NOT going to make big power. There are always TST or comp boxes for sale in the classifieds. Pick one up! There are plenty of knowledgable guys on this site that can get you to whatever HP level you want. There are also plenty of threads about how to get 400, 500, 600+ hp. Try a search.
I'm kind of thinking your just on here to "stir the pot"........
You have a truck, not a gas powered car. You've doubled the weight and cut down the aerodynamics considerably, so to compare the two is ridiculous. If your so unhappy, why not sell your truck, dig out your Members Only jacket and by another Fireturd or Trans AM?
Right.....If you had done the research that you claim, you would have known about the differences between the Smarty and Comp, Smarty 2nd Gen vs Smarty 3rd Gen, that the Smarty is not marketed only as a "power programmer" and finally that the Smarty when stacked with a fueling box is "the" combo.
yeah i have a smarty and it is almost useless...there are guys who like it although i only have it to read codes and for high idle...other wise it would have been on EBAY the day after i bought it...and yes i have mine stacked with a drag comp...i would only recomend it if you are looking for high idle or else if u wanted to read you codes..
